Question about Electrical Supplies
I have a tecumen engine 8 hp and It will not keep runnung, will start with starting fluid and then dies, The oil level is ok , It is a coleman generator
    President:
  • 1,922 Answers
Take the sediment bowl off the bottom of carb and se4e if theres rust, dirt in there and dont lose bolt or bowl gasket when doing so they may fall off when you remove the bowl, then you will need to use carb cleaner or have unit torn down and thoroughly cleaned
Posted on Oct 07, 2009
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Car won't start & leaking lots of some kind of fluid
The computer stopped the car to prevent you driving it and destroying the engine. So you will not be able to restart it until the problem is fixed.
Have you checked any of the following:
== engine oil level
== radiator coolant level
== if its an auto trans, the auto transmission fluid level.
Drop a white tissue into the fluid the car is dropping. Is it watery or oily and what colour is it.
Dec 23, 2012 | 2001 Acura MDX
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
I have a Briggs and Stratton 21" Rotary Mower--Model Series 410. I have found that when I start the engine it eventually dies out smoking due to oil in the gas tank. Do not know where it is coming...
You parts manual is in the link below:
http://www4.briggsandstratton.com/ipl/pdfs/100/MS0669.pdf
Item 8 on the die of the engine is porting oil to your carb. Most of the time the reason for this is that someone seriously over-filled the engine with oil so as a crankcase breather it is shoving the excess oil out of the crankcase and into the carb throat. Hence your seeing massive smoke and the engine eventually dies out.
Re-check the engine oil level. There are 2 lines on the dip stick. The oil should NOT be above the upper line.
If the oil level is fine then remove the crancase breather from the side of the engine and submerse it a cleaning solvent. (I can not tell you to use gas but I do) Let it soak for quite a while (8 hours) And then clean it off with carb cleaner and re-install it.
I honestly think you have a simple case of too much oil in the engine. Adjust the oil level to the proper levels and try again. It will smoke for a couple of minutes while the residual oil id expelled but it should snap out of the current symptoms shortly there after.
If none of the above correct the problem just respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Aug 31, 2011 | Briggs & Stratton Ignition Kit 2-8 HP...
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
I have a coleman powermate generator 5000 in from 2006. Has never been started. I tried to start, filled the oil/gasoline and It would not start. What can I do beside's taking it in for service.
Remove the air cleaner and spray some starting fluid into the carb. If it starts then ok if not then remove the spark plug and check for spark.
Keep posting until its fixed. Give the model number PMxxxxxx.
Jul 27, 2009 | Coleman Powermate Powermate 5000W...
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
I have the same problem.
carberator needs cleaned and idle passages need blown out then put it together and retry if you clean it correctly it should solve the problem. first check to seee if you have a engine kill switch wire thats hitting the ground that will kill the engine too
Jun 22, 2009 | Karcher 2500 PSI Pressure Washer
Electrical Supplies Logo
137 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
