We have a Carrier mini split AC that we are wiring on a portable office that will be going to a foreign country, the Carrier #38QG24-H. This unit's voltage specifications is 200-240volts, single phase, 50 Hertz. Question we will have a normal (USA)electrical panel with 240volts single phase and 50Hertz. Can I connect this AC off of a 2pole breaker? Someone suggested that he thought we could only connect off of a single phase (1-pole?)(phase to neutral or ground) of the 220/380volt local service. (I'm not sure if they even have a neutral) before we transform the office power to 120/240volts. Ken
  • 128 Answers
Please 200- 240 volts is a standard for all and for the breaker is depending of the country if 120 v single phase you will install as usa if 220 v single also you can connect you breaker but the problem is some countries are not 50 hz comfirm the unit is 50/60 hz.
Posted on Sep 24, 2009
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
Carrier ac E4 error
If this is a ductless mini split e4 appears to be an air temp sensor on the indoor or outdoor unit that is sensing an abnormal reading. Check air filter and both I.d & o.d coil cleanliness. Its hard to troubleshoot without a model number. If its a 38g or 40g in the model number its a discharge temp sensor reading high temp situation (dirty o.d. coil, low freon, refrigerant restriction. Again, need a model #
May 29, 2015 | Carrier Heating & Cooling
I have a 14.4 square metre office room, fitted with 12000btu split AC unit for cooling, will it be sufficient?
1tr could cover up area of 100 Sqft ( Nearly 10sqmtrs) 12,000BTU is 1Tr. Better you go with 1.5 Tr. Otherwise make any patrician work to short the area, if you can. Thanks.
Feb 01, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR CONDITIONER i need to know how to program the remote control.
i want know that how can connection wiring of indoor panel and out door panel 0f carrier 42qg24-c / 38qg24-c ?
(i need wiring diagram)
Feb 09, 2010 | Carrier BCA101R Air Conditioner
POWER LIGHT FLASHES 5 TIMES CARRIER SPLIT SYSTEM 42PI00H
carrier split ac blinking 5 times & stop the unit
Sep 03, 2009 | Carrier Heating & Cooling
Geting ac to automactically restart after power has gone out
IT SHOULD START ON ITS OWN THE UNIT SOUNDS LIKE A 220 VOLT UNIT SOME TIMES POWER SURGES WHEN THE ELECTRIC COMES BACK ON CAN SINGLE PHASE AND DAMAGE SOME UNITS
Aug 10, 2009 | LG LS-L1210CL Mini Split Air Conditioner
My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
May 11, 2009 | Carrier 38CKC036 Air Conditioner
Friedrich Mini-Split blowing fuse
Low voltage shorts can be a real pain to find!!! i would try a process of ellimination: first i would try to elliminate the thermostat. then id look for a wire that is vibrating on something in the cabinet.
Oct 11, 2007 | Friedrich M18CE Air Conditioner
Heating & Cooling Logo
380 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
