Question about Cell Phones
I have a symbol on my phone as if i am receiving a mms under my signal bar.i have turned the 3g off but its still there
I can't received MMS/GPRS/3D & i can't send also..
you need to set up the GPRS/MMS/3G setting
the setting is dipending on your SIM card
a better way is contact your SIM customer care to ask about GPRS/MMS/3G setting
i hope this helpful
thank you for using fixya
Feb 15, 2011 | Nokia Classic 2700 Cell Phone
I do not have wireless at home. Received the 3g version of kindle for christmas. It worked all this time. Today, it will not connect. Sees all sorts of wireless connections which are all password...
You are mixing up two things: 3G and Wi-Fi.
3G is a mobile phone data service, supported by selected Kindle devices. Your Kindle 3 3G has a SIM card built inside, just like the fingernail-size chips you put into a mobile phone. Amazon set up contracts with phone service providers in many countries so you can use it to download books to your Kindle at no extra costs for you other than the higher price of Kindle 3 3G compared to the non-3G version. You do not need any extra hardware for this to work, and it will work in most places of the world. This is the guarantee you were promised.
Wi-Fi is a wireless communication standard all Kindle devices support. While most hotels, airports and some restaurants provide free Wi-Fi access for guests, you need your own WLAN router at your home, and pay for your own broadband internet service. The "all sorts of wireless connections which are all password protected" belong to your neighbors and they are password protected so that nobody can take a free ride on the service they pay for.
You can tell the connection status of your Kindle from symbols in in the status bar, at the top right of the screen:
  • If it shows "OFF", wireless connectivity is deactivated and you cannot access the internet from your Kindle, or download books.
  • If it shows "Wi-Fi", the Kindle is connected to a Wi-Fi network. The five bars right of the symbol represent the connection's signal strength, the more bars are black, the better.
  • If it shows "3G", you are connected via 3G mobile data service. The bars right of this symbol refer to mobile phone service signal strength, much like a mobile phone would show you.
If you do not have internet connection with wireless LAN at home, you need to set up your Kindle to use the 3G service. This is the default setting when the device is delivered to you, and I believe it worked until you or somebody else inadvertently changed the configuration.
Follow this step-by-step procedure:
  1. Switch on your Kindle.
  2. Press the "Home" button.
  3. Check the status bar. Does it show the "3G" symbol? If yes, how about signal strength? If you are somehow blocked from mobile phone antennas in your area, signal strength will be low and the Kindle will not have internet access. Move around and see if it becomes better.
  4. Does it show the "OFF" symbol? If yes, press the "Menu" button. A menu of commands should open. Use the four-way button just below "Menu" to underline the top-most option "Turn Wireless On" and press the center of the four-way. The menu list will close, and after a moment Kindle will try to connect to the internet.
  5. Does it show the "Wi-Fi" symbol? If yes, I assume you accidentally connected to a neighbor's Wi-Fi network and its firewall protected, or is too far away to use it. In this case, press the "Menu" button to open the command menu. Use the four-way button just below "Menu" to underline "Settings", second option from the bottom, and press the center of of the four-way. The settings menu will open. Use the four-way button to navigate down to "Wi-Fi Settings" (the text "view" must be underlined) and press the center of the four-way. The list of Wi-Fi networks open. Navigate down using the four-way to any network with the text "forget" on it and press the center of the four-way.
Please let me know if you encounter problems in following these instructions, and I'll try to assist you further.
Jan 08, 2011 | Amazon Kindle 3G
I tried to enable mms on my 2g. I installed Native MMS2g and I reset the phone. Now it will not turn on. The little apple icon comes up but the phone never turns on.
To enable MMS on your iPhone 3G you just need to go to
Settings >> General >> Network >> Cellular Data Network
enable-mms-iphone-3g-os-30-t-mobile-01-166x241.jpgenable-mms-iphone-3g-os-30-t-mobile-02-166x241.jpgenable-mms-iphone-3g-os-30-t-mobile-03-166x241.jpg
enable-mms-iphone-3g-os-30-t-mobile-04-166x241.jpgenable-mms-iphone-3g-os-30-t-mobile-05-166x241.jpg
Then Under MMS, enter the following details:
  • APN: wap.voicestream.com
  • Username: leave blank
  • Password: leave blank
  • MMSC: 216.155.174.84/servlets/mms
  • MMS Proxy: 216.155.165.50:8080
  • MMS Max Message Size: leave blank
  • MMS UA Prof URL: leave blank
Once entered, reboot your iPhone.
Go to Messages. There you will find the sweet little camera icon to the left of the text input box.
Congratz you have enabled MMS on iPhone 3G OS 3.0 for T-Mobile. You can use that icon to send Pictures, Audios and Videos to your loved ones at the same price as of a Text Message means NO additional charges for MMS on T-Mobile Network.
Cheers!
Feb 06, 2010 | Apple iPhone Smartphone
HTC Touch Diamond 2 (E) sybol problem!
E symbol is to indicate htat you have active EGprs connection....
This E symbol gets greyed out only , when you are out of reach or when you dont have proper sgnal..
Since the signal is very less, you were not able to send or receive SMS or Call..Try checking with open space...No Issues with your mobile
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 07, 2009 | HTC Touch P3450 Smartphone
How to turn on 3g for video calls
3G should be automatic when you come in range of a 3G network. For MMS you have to contact your provider (mobile service) as they might require you to download some settings before you can use MMS. Have a look on the services website and it may have some more info there, otherwise call your customer help line.
Mar 13, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
Problem..
reset your phone on factory setting
Oct 07, 2008 | Motorola Mobility RAZR V3x Cellular Phone
3G symbol
It means that you are receiving a 3G signal (which means your phone can send and recive information at a much quicker rate- for internet or video call for example), it has nothing to do with any buttons you have pressed. It could also display an E or an H in the same position on your display.....depending on your network or ......
I could go into it more.......but i'll keep it brief. you get the idea!
Aug 18, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Pc suite
If you mean connecting the handset to the PC and using it as a modem then if you make sure you have 3g switched on and have a signal then this will increase the speed . the 3g symbol is like a blue box with waves coming out of it ( when you see it you'll know what i mean ) its right next to the signal strength bars .
Mar 09, 2008 | Sony Ericsson K800i Cellular Phone
Cell Phones Logo
81 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
