Question about Bang and Olufsen BeoSound 3 MP3 Player
The controls do not respond when selected. What do i do?
  • 3,741 Answers
Either its a internal problem that the touch pad is got short and needs repairing.or the device is got hanged.if touch pad is faulty you will have to get it repaired the touch pad or get the touch replaced.but if its the device got hanged problem ,then there is a reset hole provided in the unit.Reset hole... Use a pen or similar pointed object to reset all settings...Please note, all music content is still intact.on the broad side of the unit there is a small hole provided inserting pen in that hole and pressing the internal button resets the device and it starts functioning.
if you are not aware of the location of the reset hole.pleasde click this link directly in this its clearly mentioned where the hole is
http://www.retrevo.com/r/23282ci653/8/Setting+up/
thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 24, 2009
How can i unlock my keyboard
Recognize that you have a locked keyboard.
If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
Use your mouse to move the pointer over the "Start" button.
Use the left-click button to bring up the "Start" pop-up menu.
Position the pointer over "Settings" and use the left-click button to select. T
hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
Select "Accessibility Options" to bring up another menu, then select "Keyboard."
You'll see three options that have check boxes.
Make sure each check box does not have a check mark in it.
The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
Turn off the computer.
Disconnect the power supply.
Remove and then reconnect the keyboard cable, then reconnect the power supply.
Turn the computer on.
This will reboot the computer, allowing it to recognize the keyboard.
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
Dot s touchpad not responding
Use an usb mouse to select control panel and then select device management. From there you need to select the mouse and from there select the mouse and right click on it. Select to uninstall the device. Then close all screens and shut down computer. Unplug the usb mouse and restart the computer. If after it completes loading and it doesn't work the you will need a new touch pad. But if it does work it means windows had an corrupt update which caused the problem. Thanks Igor!
Sep 29, 2012 | Computers & Internet
What's your problem?mw 715 keyboard not responding
The problem is in the keypad control board, replacement only option.
Apr 25, 2012 | Microwave Ovens
I would like to know the code for my dvd player its a RCA please
Hello
Setup code for RCA with Philips SRP2003/27 is:
2351
[1] Make sure the receiving device is able to
respond. E.g. when you try to repair the Play
key for your DVD player, make sure to insert
a DVD into the DVD player otherwise the
Play key is not able to function.
[2] Select the device
that you wish to
operate (e.g. DVD).
Press the (DVD) device
selection key to
select DVD.
[3] Keep keys (1 & 4) and
pressed
simultaneously for 5
seconds
The red Setup
light lights
up. The remote control is now in setup
mode.
8 EN
[4] Press and hold the key that does not
function and immediately release it when
the device responds.
* If the key still does not function as expected,
try pressing it again for a longer period of
time.
[5] Press the (DVD) device
selection key twice
to save your settings
and exit setup
mode.
When no key
is pressed for 5 minutes or more, the
remote control will exit setup mode,
automatically saving all your settings.
OK.
Aug 15, 2011 | Philips SRP2003/27 Remote Control
PROBLEM WID THE KEYBOARD,TOUCHPAD IS NOT RESPONDING.THE ICONS DO NOT RESPOND.THE MACHINE WAS SHOWN AT THE SERVICE CENTRE,REQUISITION FOR NEW KEYBOARD PENDING SINCE LAST MONTH.KINDLY HELP ASAP.
try plugging in a standard desktop keyboard & mouse
if works the problem is probably the onboard keyboard/touchpad
if not work probably driver problem
try restart while pressing F8, select safe mode
if works go to control panel & check mouse settings
if ok either malware - run anti-virus application
or is bad hard drive media - run error checking
right click C: drive, select Properties, select Tools, select Error Checking, follow instructions
Nov 04, 2010 | Acer Computers & Internet
I forgot the code of my sharp tv (pin code) please what can i do
Try to press code search then select tv, then keep pressing power on button until the tv respond. Then press enter after it respond.
Oct 21, 2010 | Recoton Advent Advent ADR-560 Remote...
Logitech harmony xbox 360 remote not communicating with 360.
There is a setting that may need to be changed within the Xbox 360, to allow it to be controlled by a Harmony Advanced Universal Remote.
To configure your Xbox 360 to respond to a Harmony Remote
  1. Using your original Xbox 360 controller, go into the Xbox Dashboard on the Xbox menu
  2. Select "Console Settings"
  3. Select "Remote Control"
  4. If "All channels" is selected, select "Xbox 360 Media Remote”. If "Xbox 360 Media Remote" is selected, then select "All channels"
Your Harmony remote should now control your Xbox 360
Oct 20, 2009 | Logitech Harmony 360 LCD Remote Control
"AMP" button on Sony RM-VL 900T stopped responding
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
To reset all functions for a Component: Press and hold [S] until the green indicator lights. All Component Select buttons will flash. While holding [STOP], press the desired Component Select button.
Dec 27, 2008 | Sony RM-VL900 Remote Control
Printer won't respond
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Jun 29, 2008 | Epson Stylus C62 InkJet Printer
Bang and Olufsen BeoSound 3 MP3 Player Logo
233 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
