Question about Maytag MSD2756G Side by Side Refrigerator
The switch on Maytag water and ice dispenser hangs
The switch on Maytag MSD2756DE water and ice dispenser hangs up, sometimes causing overfilled glass.and spillage.
  • Maytag Master
  • 909 Answers
Need to enquire from the agents if that dispenser switch is available as a spare part. If so, switch off and strip carefully as logic shows you.
Posted on Sep 24, 2009
I have a Matag MSD2458GE refrigerator. Water dispenser on the door works but, the ice maker doesn't work at all. Seems no water reaching it. Needs new filter, but no ice before replace filter light.
According to your user's manual, "If water flow to the ice maker or dispenser decidedly decreases or if an objectionable taste or
odor returns,change the filter sooner than
recommended."
"Leave the refrigerator door open while removing and installing filters or plugs; this will prevent water
from flowing through the system and running into
the fresh food compartment.
• A newly installed water filter cartridge may cause
water to temporarily spurt from the dispenser"
Automatic ice maker not operating
the stop arm in OFF (up) position
•the water supply turned off
•the water pressure too low
•the freezer too warm
Ice dispenser not operating
ice jam in the dispenser
•ice maker not operating
• lock switch on (see page 11)
Water dispenser not operating
• water pressure too low
• lock switch on (see pg. 11
To locate an authorized service company in your area,contact the Maytag dealer from whom your appliance was purchased; or call Maytag
Appliances Sales Company,Maytag Customer Assistance at the number listed below. Should you not receive satisfactory warranty service,please
call or write:
Maytag Appliances Sales Company
Attn:CAIR
Center
P.O. Box 2370
Cleveland,TN 37320-2370
U.S.
1-800-688-9900
CANADA
1-800-688-2002
U.S. customers using TTY for deaf,hearing impaired or speech impaired,call 1-800-688-2080.
Feb 24, 2017 | Refrigerators
Maytag mfi2568aes control panel
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
May 16, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
Ice and water dispensing intermittently on my Maytag model MF2568AES12 refrigerator. I replaced the light switch in the freezer, which didn't help. What should I do next?
On top of the fridge underneath the plastic cover for the door hinge probably on the door with the water/ice dispenser should be a wiring harness. This runs the ice dispenser and water. There should be a wiring harness plug there. Try unplugging it and reconnecting. This may be the cause since you said it's intermittent and with opening and closing the door it may be causing the plug to ever so slightly move around and loose electrical connection.
Oct 18, 2013 | Maytag Refrigerators
My Maytag msd2556ae will not dispense water throught the door. It makes ice just fine, and will dispense ice through the door, but not water. I've replaced the filter in the fridge, but no change.
There could be a blockage of its iced up. A complete defrost might fix it.
you'll have to leave it switched off with the doors open for 24 hrs.
Sep 01, 2012 | Maytag Refrigerators
Ice maker is not filling the ice cube maker. model Maytag MSD2756DE
check the water valve on the back bottom of the frig-mike
Jan 09, 2010 | Maytag Refrigerators
Ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Sep 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
We have a Maytag side by side refrigerator. We
Sounds like your icemaker is overfilling if you are finding a layer of ice in your freezer compartment. I would change your water valve located in the back of the unit. Or look at the icemaker to see if there is ice cycles hanging down from the tray. If you do not see any, you may want to look at your freezer drain to see if it is clogged causing water to be drained in your home. Coulc be several different things honestly. Hope this helps!
Apr 08, 2009 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
390 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
