Question about Nespresso Aeroccino Automatic Milk Frother
On/off problems Frequently when I press the on/off button, the light merely flashes and does not stay on or the frother froth. Sometimes it takes 20 or 30 attempts to get the frother to operate. Usually I just give up. Is this a recognised problem or should I have it replaced? Michael
  • 7 more comments
  • briyorks Dec 26, 2007
    Exactly the same problem with mine - bought new this Christmas and worked first time but the on off light only flickers for a short while now.
  • wypke Jan 01, 2008
    the thing just stopped working for no aparant reason..
  • FRANKCLOCK Feb 08, 2008
    I HAVE HAD THE SAME PROBLEM WITH MY ITEM I RETURNED THE FIRST & IT WAS REPLACED, THIS ONE DID THE SAME, IT WAS RETURNNED THEY SENT IT BACK SAYING IT WAS OK AND IT FAILED TO WORK AGAIN!! I EMAILED NESPRESSO IN SYDNEY WHO HAVE OFFERED TO SEND A NEW ONE, HOW LONG WILL THIS WORK FOR
  • james122 Feb 19, 2008
    Me too, Mine just stopped working no mater what I do.
  • Anonymous Mar 02, 2008
    Mine worked for three months but no longer. With only one button to play with, there aren't many ways to troubleshoot the issue. Not sure where to send it for repair?
  • bapfel Jul 17, 2008
    Same problem - called Nespresso customer service and was told not to store it on the base with the base plugged in - by doing this there is always power to the unit and the motor burns out. They sent a new one 2-day air and I've been following their suggestion - no problems so far. Was impressed with their customer service.
  • Anonymous Aug 07, 2008
    same problem....aeroccino maker light turns on, wheel starts to spin, then stops. hit the button & the wheel begins to spin then stops. the machine is just not working properly. i'll try to leave it plugged in for 30secs 1st then turn it on & c what happens. SG
  • diane_whiteh Nov 10, 2008
    Mine worked for 2 years, no problems now I have 4 and none of them will froth!
  • Anonymous Mar 19, 2014
    My machine is the small frother with snap on discs
Had the same problem. I tried this:
1. left the aeroccino on its base (plugged in) constantly.
2. poured milk into aeroccino while on base, do not start, wait for at least 20 - 30 secs for the thermostat to adapt.
3. in the meantime work on brewing the coffee.
4. again, wait for at least 20 - 30 secs, then press the aeroccino button.
I have followed this for a week now and it always works, no early switching off anymore.
hope this helped
KG
Posted on Oct 05, 2008
This may or may not help your problem. I found that rinsing the aerocinno out with cold water after each use ensures the next lot of cold milk is heated to the correct temp. If I don't do this it cuts out too early. If you are heating cold water and then putting in milk it definitely won't work as the thermostat will be at too high a temp and will cut out.
Posted on Jul 28, 2008
I HAVE TRIED MINE WITH TAP WATER & IT WORKS EVERY TIME AS SOON AS FRIDEG MILK GOES IN THATS WHEN WE HAVE A PROBLEM, PERHAPS AN INTERNAL THERMOSTAT PROBLEM ??
Posted on Feb 08, 2008
Found out if you just leave it for 30 seconds after turning the power on but before activating it works fine.
Posted on Jan 24, 2008
My nespresso milk frother red light doesn't come on, it is staying blue
I found that when I switched milks from whole to two percent organic it stopped frothing. When I tried a friend's creamer it worked again.
Oct 12, 2013 | Nespresso Aeroccino Automatic Milk Frother
Aeroccino frother won't turn back on after we get some froth and still more milk in container.. takes a long time to be able to activate again.. using Almond milk could be the problem any suggeest
My Nespresso Aeroccino often would not heat or froth multiple times after one use. I called Nespresso, they have excellent customer service, and was told to rise the inside (careful not to get the outside button or electric elements wet) of the Aeroccino with cold water a few times and to retry. Works like a charm!
The customer service is the best I have encountered in a long while, give them a call, it will make your day they are so pleasant and helpful!
Feb 18, 2012 | Nespresso Aeroccino Automatic Milk Frother
What does a blue light mean on my aerochino? thanks.
Means you are not heating your milk, the frothing milk will be cold (for iced drinks) because you have held the button down longer than normal. Usually it takes 5 Seconds for the blue light to go on. try turning it on or pushing the button faster, It should turn on red, for heated and frothed milk.
Nov 10, 2010 | Nespresso Aeroccino Automatic Milk Frother
The milk in the frother won't foam. I tried different kinds of milk but still doesn't work
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Sep 14, 2010 | Nespresso Citizmilk C120
How do I make cold froth on my aeroccino for my lattes?
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
Jun 27, 2010 | Nespresso Aeroccino Automatic Milk Frother
How to get cold froth
Press and hold the button for 5secs or longer untill the light turns blue.
May 29, 2010 | Nespresso Aeroccino Automatic Milk Frother
My Nespresso milk frother did not come with instructions. Is there some way to froth but not heat the milk?
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Jan 25, 2010 | Nespresso Aeroccino Automatic Milk Frother
Nespresso Aeroccino Automatic Milk Frother Logo
3,950 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
