Question about Motorola XU2600 (6 Channels) 2-Way Radio
External mic wont work - Motorola XU2600 (6 Channels) 2-Way Radio
Mic is not working on acer aspire 7736z-4905
have you tried plugging in an external mic?
If it works with an external mic, chances r that the issue is not hardware, but configuration within your operating system
Apr 05, 2013 | Computers & Internet
Does the acer 5517 have a built in mic
Acer 5732z has a webcam but there is no built-in mic, you need to use the external mic connector (pink/red).
Feb 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
When i plug in a mic, it wont work. under
You need to do the following
1. Open Sound & autido devices from controlpanel
2. Click Advanced button in Volume tab
3. Select properties from Options menu
4. Select Recording & press ok
5. Select External MIC instead of others
Aug 02, 2009 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Dell LAtitude D600 mic wont work
right click on volume in right hand toolbar and open volume control then click options and then properties tick all boxes scroll along to mic and turn slider up should fix.
May 08, 2009 | Dell Latitude D600 Notebook
Hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
Apr 11, 2009 | HP Pavilion dv6000z Notebook
External mic for Panasonic DVC80p
on page 49 of your owner's manual, the operation of the mic input switches is described.
Mar 04, 2009 | Panasonic AG-DVC80 Mini DV Digital...
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Sep 16, 2008 | Canon HV20 HDV Digital Camcorder
Motorola XU2600 (6 Channels) 2-Way Radio Logo
19 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
