Question about Poulan Garden
I need to replace the trimmer line on my Weedeater brand TE 400 CXL weedeater
3 Suggested Answers
  • 57 Answers
SOURCE: how to install the Speed Spool Bump Knob Assembly
Do you have an owners manual? If not, try poulan.com
Posted on May 19, 2009
rycgl
  • 1545 Answers
SOURCE: My te 400 cxl weedeater
People replace fuel lines all the time as they deteriorate over time. This is a fuel delivery problem most likely and will require installing some new parts in the carburetor to fix. You can go with the cheaper diaghram kit or a full rebuild kit (includes the parts in the diaghram kit). This is a very, very common problem with these machines. If you feel you have to clean the carb at any time, only use non-flammable brake cleaner spray on it. Stronger cleaners and carb sprays can damage very sensitive internal parts. Don't use any high PSI air on it either as this has the same result as the strong cleaners. As far as an air line goes, these machines probably don't have one but they do have an air filter that needs to be checked or cleaned or replaced. They also have a fuel filter that is located on the end of the fuel supply line inside the fuel tank. Check that also.
Posted on Aug 15, 2010
Weedeater line restringing
Usually following the instructions in the owners manual will get you thru this task .weedeater brand is not a worx and we have no idea which you have
Jun 10, 2016 | Worx Garden
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
My te 400 cxl weedeater starts but won't continue to run. can I replace the fuel or air line?
Aug 14, 2010 | Garden
I need to replace fuel line in Weedeater trimmer. How can I do it ?
Enter Weed Eater fuel lines in the search field for numerous results and if not, repost here.
Aug 07, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Featherweight weedeater primer bulb repair?
featherweight weedeater - runs rough and has no power
Jul 03, 2009 | Garden
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Replaceing string spool
if its the newer weedeater brand
All you need to do is grab the bump knob end and pull it straight off no turning
wind your line in the direction the arrows on the spool shows you
to put back insert line or lines into the holes and snap back on
be sure the spool is able to move up and down freely after install
May 26, 2009 | Garden
Garden Logo
185 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
