Question about Kalimar V-20S VIDEO TRIPOD
Need missing part to tripod
I am missing the plastic part that has a metal screw on it that screws into the camera then is clipped into the bracket on my Kalimar tripod. I don't see any model number on the tripod. It is about 2"x 2".
Thanks,
Gary
3 Suggested Answers
jessee007
  • 310 Answers
SOURCE: Kalimar Pro V-40 Tripod
If you have lost the screw no problem. Take the camera with you and go to you r local hardware store and fit it with a new bolt or srew.. It will be a standered size and thread. I loose this part all of the time
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
tbreeze47
  • 3083 Answers
SOURCE: The screw that keeps the
You're going to have to go to the manufacturer for the parts list, and that is sometimes not available, since their repair facilities would have them, and it would take quite an effort on the manufacturer's part to track it down.
What would probably be an easier shot at figuring this out, would be to take the tripod in to a camera repair shop, and see if they might be able to give you an idea of the screw and thread size. If that doesn't help, there are hardware outlets that might be able to run down the right screw for you.
I couldn't find any internet support for this company, and if nothing else works, you might see if they have a contact phone or email on their literature that came with it.
Good luck, and hope this helps.
Posted on Oct 03, 2010
How do I keep the button down when screwing the camera on
I suspect that this is the tiny locating button that sits beside the screw on the tripod.
Check your manual to find out how to remove the quick release sled. There is usually a small lever that needs to be rotated out of position and the sled lifts out.
Once you have the sled out, turn it over and you should see a small flap of metal that can be folded up and this is the means by which you screw the threaded part into your camera. Once it is tight, flip down the metal flap and then refit the sled to the tripod , taking care to rotate the lever again.
Some tripod levers remain locked while the sled is removed and they slip back into place when it is replaced in the tripod head.
Hope this helps.
Sep 17, 2014 | Sunpak PlatinumPlus 6000PG 61" Tripod
How to remove car door panel
The door panel is held in place by 2-6 screws and several clips. Remove the screw from the handle and lever under the plastic caps. The speaker may be secured to the door with 3 screws (this varies per vehicle). The is a small plastic cover near the side mirror that must be removed with care. It pulls straight out, but the metal clip in the plastic may need help from a flat blade screwdriver.
There are several screws that hold the plastic rain shield in place. Remove the rain shield carefully.
Additionally, there are several videos on YouTube that demonstrate the process. The last one I viewed missed the screws in the door in my 2001 Odyssey.
Aug 07, 2014 | 2003 Honda Odyssey
The screws on my tripod will not tightened
Take out the whole Camera Plate. there is a plastic cap on the top of the tripoid, right by the end of your tripod extender, that comes out with a little pulling it. Now, have a look at the end of the knob housing from which your screw accidentaly came out. You will see a perfect spot in wich you need to re- insert the nut that came out. Once you do it, all you need to do is to re- insert the knob back into place, and it will "bite" the nut again at the end of the housing. Re- install the whole plate back on top of your tripod. Finally, put the plastic cap back at the top. You might need to gently tap it in. Done deal . Problem resolved ! Enjoy your tripod !
Jan 21, 2012 | Zeikos ZETR57A Tripod
I need to purchase screw that attaches scope to window mount on a 78-4405
The mount has a 1/4-20 screw that fits most camera equipment. If you have the scope (spotting scope) it should have that hole in the bottom of the mounting ring. If the screw is missing from the window mount then most 1/4-20 tripod screws will work or you may substitute a cap screw and flat washer, to work with an Allen wrench for tightening.
Feb 07, 2011 | Bushnell 784405 Tripod
How to put a camera on it
If it's a quick release tripod you need to remove the quick release plate (Usually a release lever to the side of the top of the tripod) and then fasten the plate securely to the camera and then the plate to the tripod. Older non-quick-release tripods have a knurled screw located below the flat area where the camera is attached. If the screw is missing, get a relacement from your local hardware store - 1/4" -20. (Find a way to keep the new one from getting lost.)
Jun 12, 2010 | Ambico 67" TRIPOD
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
Need parts list VPT 360SE tripod
'camera mounting scrwe'..any good camera store or online... samy's camera for example
Dec 02, 2008 | Vivitar VPT-360 PROFESSIONAL FLUID-ACTION...
Mounting bracket
added a spacer made from a truck inner tube. the screw from the tripod still has 2 full threads threading into the bracket on the telescope.
Sep 23, 2008 | Optics
Viviteck 3x optical zoom, battery door does not close
I got an estimate of $125 to fix the Coolpix 7900 door, and the camera probably isn't worth that much. So I looked more closely at the camera to create a jury rig fix. As I never use a tripod with the camera, I thought about using the threaded tripod mount. I found a very short 1/4 inch thread screw in my garage and cut a thin metal strip to about 2 1/4" x 1/2". I then drilled a 1/4" hole at one end of the strip, laid the strip across the door and tightened the screw through the 1/4" hole and into the tripod mount. The door is now secure. To remove the battery, I simply loosen the screw a little with a dime and pivot the metal strip out of the way. There are many variations that can be done similarly such as using a plastic strip and a plastic 1/4" bolt or even a shorter strip that just covers the door.
Aug 07, 2008 | Cameras
Replacement bracket for qtb-7500a
Never seen one in stores the ony replacement I have seen was the one that goes to the tripod and then screws in the botton of the camera...
May 28, 2008 | Cameras
Photography Logo
42 people viewed this question
Top Kalimar Photography Experts
JP Services
JP Services
Tony Parsons
Tony Parsons
TC CAMERA REPAIR.Com...
Are you a Kalimar Photography Expert? Answer questions, earn points and help others
