Question about Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Laptop in continual stop start cycle
Hi
I have a Lenovo Laptop Type 0768-41G, the problem is it is in a contiuous stop start cycle. The hard dri ve fell out and now comes to black page with 5 options for starting:
Safe mode
Safe mode with Networking
Safe Mode with command prompt
Last known good configuration(your most recent settings that worked)
Start windows Normally
No matter what you select it gets to windows XP page with blue bar at the bottom it then stops and goes blank, white lenovo page then comes up and it continuously cycles doing the same thing.
Can anyone help please
  • 822 Answers
Please the memory RAM with the same type and specifications.
Posted on Sep 24, 2009
When i turn on my lenovo g585 lap it start with one beep and comes the display and go boot with continuous beep sound and stuck the lap
Hi...
Gives continuous beep sound , When my laptop switch on (Lenovo G585). No display but leds (power & battery) were blinking.
Sep 10, 2013 | Lenovo G585 Laptop
My lenovo z500 has a screen brightness issue. It very dim and it won't turn up no matter what I do?
Hi, I had this problem also and I don't know why, but Lenovo Ideapad Z500 seems to have some compatibilities issues with a new Intel video card.
So, what you need to do is rolling back the HD intel video card driver to the previous version OR go to the following path: D:\drivers\VGA\Intel\x64\9.17.10 and press Setup to install the old driver again.
That solved my problem. It's a shame that I can't upload this driver in my laptop.
Mar 18, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
Laptop is not switching on
The Lenovo maybe damaged beyond repair.
You should not have turned on your Lenovo and imediately removed the battery then drained the water and place the Lenove in a warm dry place for several days to make sure it was completely dry, then take it to a computer repair shop and get them to check out the Lenovo.
I suggest you take it to a computer repair shop, they may charge you for a quote unless you go ahead with the repair.
You could remove the battery and dry out the Lenovo for several days and then replace the battery and then boot it up. If it does work then I suggest you get a new laptop.
You can remove the hard drive and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 12, 2012 | Lenovo 3000 Y410 Laptop
HI..i have a lenovo G550 laptop... the problem is that i can get in to BIOS or BOOT menu i've tried every key F2 F12,, nothing works..pls help me..
Try with External USB Key board. To enter BIOS setup utility, press F2 when the Lenovo logo appears during starting up your computer.
Hope this helps to you....
Jun 18, 2011 | Lenovo G550 Notebook
Kenmore 600 electric dryer continues drying through entire dry cycle and never stops. Is this a sensor problem..or another part that is needed??
Sounds to me like a bad timers...
that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 28, 2010 | Kenmore Dryers
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Water runs contiuously... tub never fills...cycle doesn't start.
Hi, You need to reset the drain hose. It needs to be over the water level in the machine. If you have it in a sump pump, it needs to be out of the water in the sump. If I can help you further, please let me know
Thanks
Vic
May 16, 2009 | Roper RTW4100SQ Top Load Washer
Lenovo R61 won't get to login
I,d suggest To charge the battery Fully.
Then power up the laptop, with A/C Adaptor connected.
Also check your models user manual, regarding the sleep/hibernate mode. the laptop may have gone into one of these modes. Usually a ( zzz ) Icon Key or Similar.
Also when booting press the LCD/VGA Button.
If all else fails, try to see if your laptop, has a hard-reset button or switch. ** Sometimes this can be a small hole ** On the underside of laptop. *** Only use with laptop Powered Off ***
Mike @ Compurepair.
Jul 03, 2008 | Lenovo R61 T7300 Notebook
Dishwasher continuously fills....even when switched off.
Sounds like there maybe something stuck underneath the float, The float is the round coffee cup like thing in the bottom of the dishwasher That happend to me and something was just stuck not letting the float rise. I sure hope this help you out I just seen you thread and thought I would try to help you out Hope it does
Dec 12, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Lenovo 3000 N100 CoreDT2080 VB PC Notebook Logo
104 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
