Question about Hotpoint Washing Machines
Hotpoint WT960G Washer, I Have changed 3 Phase power board at bottom of the washer for new one ,as Display not working. Machine not powering instantly with new board, after 30 seconds or so will power but get long beep(2-3 seconds) no functionality after this and still no display. put in old board and powers instantly with full functionality still with original display fault.Have tried with 2 different new boards. The new and old boards are virtually the same but with a few differences however hotpoint and spares company state that the new one is legitemate replacement part, what am I doing wrong??
    President:
  • 1,723 Answers
You're changing the 'motor control unit'. The three phase power unit controls/powers the motor.Your problem is with the display. Have you checked the 'display unit' and the ribbon cable connector?
Posted on Sep 24, 2009
  • Craig Butler
    Craig Butler Sep 24, 2009
    Give me the complete model number please.
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Hi!3-phase motor wires brn/blue/blk no open cct.P.c.b there are no components burnt out or blown.I removed interlock switch and will buy new one and try again.Belt ok.Pump solenoid valve ok .
Check for a motor start capacitor that is defective. This can happen without external symptoms. Highly unlikely Hotpoint washer has 3-phase motor. Most household loads are single-phase. In North American residences, three-phase power might feed a multiple-unit apartment block, but the household loads are connected only as single phase. In lower-density areas, only a single phase might be used for distribution. Some large European appliances may be powered by three-phase power, such as electric stoves and clothes dryers. Three wires could be for different speed ranges or one could be frame ground.
Apr 08, 2015 | Hotpoint Washing Machines
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
Fisher and Paykel Washer GW 609 when switched on at wall keeps pumping
The best bet is to have an authorized serviceman test the control board for continuity. It is out of phase and cannot reset to the normal start position.
Feb 27, 2014 | Fisher and Paykel Washing Machines
Water won't drain away from the drum. I think I may have a blocked filter. How do I access to clean the filter on a Hotpoint WT960G washing machine please. Many thanks.
Most Hotpoint washers do not have a customer accessable drain cleanout. Also, it may be a full or partial pump failure. Replacing the pump assembly will improve washer performance.
Replacement pump is about 20 Pounds delivered, and can be self installed quite easily.
Link to video
May 03, 2011 | Hotpoint Washing Machines
The display panle lights are flikering and hard to read, do i need bulbs or a new panle on wt960g
Hi.
If you can, remove and refit the nleads going to the display module, if this does not cure the fault, then it is going to mean a new board as you cannot repair a flickering display, due to the way the board is designed.
Mar 25, 2011 | Hotpoint Washing Machines
Hotpoint Ultima Machine not recieving any power
have you checked that you are getting power into the machine?
Apr 07, 2010 | Hotpoint Ultima WF860 Front Load Washer
No Power
HI THIS SOUNDS LIKE A CIRCUIT BOARD FAULT PROBABLY BLOWN 3 SMALL COMPONENTS & A BIT OF TRACK ON THE BOTTOM RIGHT HAND SIDE OF BOARD.IT IS USUALLY ONE OF 2 FAULTS THAT CAUSE THIS EITHER A MOTOR PROBLEM IE CARBON BRUSHES TOO LOW OR FAULTY MOTOR THE OTHER THING THAT USUALLY BLOWS THE BOARD IS THE DOOR INTERLOCK GOING FAULTY. I HAVE REPAIRED LOADS OF THESE BOARDS & 9 TIMES OUT OF 10 ITS ONE OF THEM THAT BLOWS IT HOPE THIS HELPS!
Jul 30, 2008 | Hotpoint WMA58 Front Load Washer
Hotpoint aqxxd169
take the top of the washing machine with the 2 screws on the back pull the top backwards. keep the power or ull get electrucated now ull see white plugs just simply press them in or if that doesnt work try
and click the circuit board back in
hope this helps u out
darren
Mar 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
