Question about Omega Seamaster 2541.80 Wrist Watch
I pulled the pin out to the fullest measure and all movement has stopped. perhaps I'm not putting the pin back in properly? It's a Seamaster 600 m
2 Suggested Answers
Sundar2579
  • 26 Answers
SOURCE: find watch numbers, seamaster automatic
I hope you have Omega Dynamic?!
If yes, then the crown can be removed by appling slight pressure against the watch. The stem inside the watch is made of 2 pieces and the crown can be pulled out. But be careful, there are chances that the stem may break :-)
Posted on Sep 07, 2009
How to reset the watch
Depends on the watch. A perpetual calendar needs some one who knows how as it is a set combination of buttons to push on the movement. A Omega seamaster there is a button on the crown you need to push in for a few second and the second hand will stop, this is complicated to explain. O normal watch just pull the crown out on stop to change the date/day 2 stops to change the time.
Nov 27, 2017 | The Watches
May i have information about omega watches?
Top omega watches internet wide free delivery. For Omega watches, quality, creativity and innovation work together. It can make use of the better of materials to style its watches. visit it http://sbwatches.com/
Apr 06, 2014 | Watches
How to remove the movement from a seamaster 1342
Here is a video that will help you ,if theres no screw it will be a small button that you press bown on then pull crown out,,
Mar 26, 2013 | Watches
Look can someone help me set the digital time on my watch please its omega seamaster polaris cheers....
Your watch uses a calibre 1665 movement. You might contact After Sales Service and ask them if they would send you an owners manual. Setting the time and date is fairly straight forward but you also need to sync the analog and digital displays so it is a bit difficult to describe in just a few words.
The basic guideline is
To select function - turn the crown
To change function - pull out the crown and then turn it
To start and stop functions - press the crown
Dec 01, 2012 | Watches
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
Find watch numbers, seamaster automatic
Sep 07, 2009 | Omega Constallation 1272.70 Wrist Watch
Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Apr 04, 2009 | Seiko Watches
Differentiating omega model 2561.80 and a model 2531.80
Kris,
The only way to find out what model of Omega you actually own is to open it.  This should have been done by whoever you already brought it to.  Omega only prints their model #'s on the movement inside the watch.  If you open the watch, look on the movement, you'll know what model you own.
Jan 18, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
Omega Seamaster 2541.80 Wrist Watch Logo
Top Omega Watches Experts
DROPNDEAL
DROPNDEAL
Geoff
Are you an Omega Watch Expert? Answer questions, earn points and help others
