Question about Refrigerators
Have GE TFX25PRY side-side refrig. Makes ice but the refig and freezer are not cold enough, even on lowest setting. Found ice accumulating along the back inside of freezer and removed. Took back freezer panel off and found ice along evaporator coils from the bottom up to about the last foot of coils. What should I look for? Dudley
  • dudleywhitne Sep 24, 2009
    I have also heard that the defrost heater may not be functioning. Do you have access to the GE TFX25PRY (or similar model) repair manual to tell me where the timer and thermostat are located? Using a multi-meter, what should be the values across the heater? How do I check the timer and thermostat?
  • dudleywhitne Sep 25, 2009
    Can anyone else offer more details about the location and troubleshooting of the defrost heater and/or thermostat?
    Thanks,
    Dudley
  • 15,935 Answers
Look for the evap fan not spinning or spinning slowly. Also check the freezer-to-fridge damper for proper operation.
Also - check for a leak in the coil at the frozen/thawed transition point.
Thanks for using FixYA!!
Posted on Sep 25, 2009
  • 1,986 Answers
Start with the easy stuff. Make sure the light turns off when you close the door, make sure the doors are closed properly and there's a good seal. Check to make sure the evap fan is working as this circulates the cold air around. Make sure the compress is running.
The most common issue is usually a frost free failure. Remove the access panel in the freezer to expose the evap coils. If they're frozen, then it will block the circulation.
Other things to check would be the defrost timer and defrost thermostat (varies in location)
Posted on Sep 24, 2009
  • super_guy Sep 24, 2009
    I don't have access to a manual sorry.
    When you find it, turn the defrost timer until the fridge turns off (it
    is now in defrost mode), if the defrost heater kicks in shortly after,
    then the timer and thermostat should be changed.
    That's the extent of my experience with fridges. I haven't had actually test the readings for them
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Refrig not cold enough, ice buildup on banck panel of freezer
ice build up means your refrigerator is not going through defrost cycle. you have ice build up on evaporator which restricts your cold air flow into the fresh food side. check defrost timer, defrost thermostat located on evaporator behind the wall where your getting frost. check defrost heater. it wraps under the evap.
Jun 21, 2009 | GE Refrigerators
Refrigerator side won't cool
its iced up and needs to be thawed. you can use a hair dryer and make it fast in say 2 hours. the freezer side is blocked from admitting cool air to the fridge side. your defrost timer may be defective or you had a real humid situation that caused it to ice up.
Dec 08, 2008 | GE GSH25SGRSS Stainless Steel Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Fresh Food Compartment not cold enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 08, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
