Question about GE WBSR3140DW Top Load Washer
Kenmore 80 series wont stop filling up with water
My whole laundry room was flooded last night, the washer has worked fine and then I go out last night and the water is still filling and it flooded everywhere! I do not have the money to call a repair man or buy a new one and my loser soon to be ex husband is worthless and I can not depend on him.
Does anyone have an easy fix? I am pretty capable and can fix things, I just don't know where to start!
  • 27 Answers
There is an air line inside the machine... one side is attached to the outer tub... the other side is attached to the water level switch in the control panel... remove the face of the control panel, and see that the clear air hose is attached to that switch... if it's attached there then you'll need to remove the front panel and lid sections of the machine and check to see that it's attached to the tub... i've also seen on a few occasions the air line get clogged so if it is attached then disconnect one side and make sure you can blow through it... if it's attached at both ends and you get good airflow then the switch is bad... lemme know if you have more questions
Posted on Sep 24, 2009
Where is the reset button for a kenmore 80 washer wont stop filling water level
If this is a top loader then the vacuum line has come off of the dashpot or the water level switch is broken. UNPLUG the power-Standing in front of the washer, pry off the plastic trim strips on the left and right of the dash (control panel) Now you'll see a screw at the bottom where the strips mounted, remove ans KEEP the screws, now the dash will lift up and fold back, giving access to the parts.
Aug 17, 2014 | Kenmore series 80 Washer Motor 3363737-
Water sensor not working. Started a load of Laundry and the water did not shut off therefore flooding my whole Laundry room. How can I fix this myself?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug or turn off circuit breaker ,if the water continues to fill, that valve is sticking,it is what to replaced
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps
Gene
Jul 31, 2011 | GE Spacemaker Washer and Dryer Electric...
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer Tub Fills With Water When Washer is Not On
dtfpaf, you need to replace the water inlet valve. Easy job, post the model number and we'll get you a part number...Catriver post back.
Jan 20, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE WBSR3140DW Top Load Washer Logo
186 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
