Question about HP Officejet 5610 All-In-One InkJet Printer
Printer not responding
I just installed a new ink cartridge and i did the test sheet and that was all fine. Now when I go to print documents it just does not print. There is a message saying "printer not responding".
SOURCE: wasting paper
Put your printed page in the scanner then press the 'Scan' button
Posted on Apr 08, 2007
  • 3 Answers
SOURCE: keeps printing test sheet
I just had the same problem after putting in a new black cart. Try this:
  • Open HP Director
  • On the main window select Settings>Print Settings>Printer Toolbox
  • Open the Configuration Tab
  • At bottom right click "Factory Settings" button then "Apply"
A configuration warning popped up explaining that 'd be changing settings used by the driver. I clicked ok. AOK. (I did do an alignment just before this, but it's probably not required to fix the prob.
Posted on Jan 18, 2008
SOURCE: black ink does not print
This is quite a common problem for these models, particulary with the black not printing, to check if this is your issue print a self test page, then try a cleaning process through the tools menu if you are still not getting any black print you have the classic blocked nozzle/ airlocked printhead issue, it is most commonly seen in printers that have used aftermarket black ink at some stage and/or have been sitting unused for a while.
try the following
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
if this doesn't work the only way to clear it is to disassemble it and soak the bottom of the printhead in hot water then reassemble and clean the head
good luck
PS it only seems to be a problem with black refilled/aftermarket cartridges, haven't seen any probs with any of the colour refills
Posted on Jun 03, 2008
SOURCE: Keep getting message Press Enter to Align Cartridges
Even when I press enter and the printer aligns the cartridges and prints out the test sheet, it still says Press Enter to Align Cartridges. I also tried opening the top of the printer and closing it. Same thing happens. I also tried turning it on and off. I can give it the order.
Posted on Nov 10, 2008
EcoPcKing
  • 76 Answers
SOURCE: Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
Posted on Nov 21, 2008
Trying to print documents, white background with black typed words. Problem I have is the printed documents have solid dark blue and solid black ink and the words don't show.
Are the ink cartridges installed in the correct colour order?
Have you printed a test page through the printer's own control panel? What was the result?
Open a new document, using the default settings. Key in some test text. Try printing. What is printed?
Jan 06, 2015 | HP Office Equipment & Supplies
Hp officejet pro L7580 printer alignment failed and ink faded
Try the steps below.
Remove the Cartridges ( bottom left side of printer ) and clean the electrical ( golden contacts ) and put them back in.
Remove the Printhead ( Open the Printer cover and you will find the Carriage that moves. Lift the latch and clean the electrical contacts ( golden contacts ) with lint free cloth
Reinstall the Printhead and wait for printer to respond. IT should fix the issue.
Regards,
Sean
Apr 10, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
I have installed a new ink cartridge and gone through the cleaning process serval times but I can not get anything to print in black. If a document is in all black, all I get is a blank sheet. If I change...
The first thing to check would be your print utility. Make sure that it is aware that there is a black cartridge installed. If you've gone through the cleaning process, try printing a test page and see if that will print the black. If not, it is either a setting in your utility telling it not to print in black and white, or a hardware issue with your printer. I will look up some documentation for your make and model printer to see what else the problem might be. Please advise with any changes when you check the print utility.
Nov 05, 2011 | Brother MFC-5860CN InkJet Printer
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
Installed new ink cartridge and it won't work
HI
did you check if the printer printed a cartridge alignment sheet.
you can try power flee initially
take out the cartridge
unplug the power cord
press the power button for 30 seconds
and then replug the cable
when it asks for putting the cartridge
put the cartrige in its respective slot
also make sure that you keep t least one paper on the tray so thst the printer prints an alignment sheet
,it shjould work fine
Hope this helps
Take Care
Jun 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
adonscott
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Test sheets will print, but nothng I try to print works
Remove the 1610 printer using add remove programs adn the reload it. Sound like software rather than hardware
Apr 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
