Question about Air Purifiers
I need directions to remove the Honeywell F50A1066 EAC and bring it to a service centre. Also, do I need to enclose the opening when the unit is out?
  • 252 Answers
Your best option is to remove the cells and pre-filters and replace with a disposable box filter. IF your eac is repairable it will cost a lot - IF! Otherwise you'll need to have a tech to your home - he'll need to diagnose it in your system, in operation.
Posted on Sep 26, 2009
Putting filter back in a Honeywell air purifier model hfd-135
Hello, this is Ava with Think Crucial.
You may refer to this online manual for your model number to help you put back the filters in your unit.
Honeywell QuietClean HFD 110 Series User Manual
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 22, 2016 | Honeywell Air Purifiers
Changed filter and pre filter both lights continue to blink, not resetting
Make sure that the new filters you installed are undamaged and correctly seated in it's assembly. When resetting the unit, unit must be powered on then press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. If nothings happens, unplugged the unit from the power for about a minute and then try to reset the unit. If all else fails, I would suggest to contact Honeywell for more assistance.
http://www.thinkcrucial.com/search?type=product&q=honeywell
Ava B.
Jun 18, 2016 | Honeywell Air Purifiers
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Have honeywell air geius 5 can't reset filter lights
Ava B.
Feb 15, 2016 | Honeywell Airgenius 5 Air Cleaner/odor...
My Honeywell 5-in-1 True HEPA Tower Air Purifier with UV Allergen Remover wont turn on.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Oct 25, 2013 | Ecoquest Fresh Air Air Purifier
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Mar 11, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
I have a F50E electronic filter. The light comes on, but there is no snapping sound when I push the test button. The cells and wires look ok. What could be the problem.
It's possible that the board is at fault. Triple check and make sure all the ionizing wires are in place on both cells and that the thin collector plates are not touching each other. Also, make sure the contact points are clean on both the cells and the cabinet.
The F50 is an obsolete EAC, so parts are becoming difficult to get. If the board is bad, I would recommend unplugging the unit and using a MERV 10 media filter in its place (Honeywell designed that EAC with the same cabinet as the media filter... all they did was add a power pack on top for the EAC. The media filter will slide directly in the cells place.) You will get better filtration with much less maintenance.
Mar 24, 2010 | Honeywell Air Purifiers
F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Dec 12, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Hi, I have a question about Honeywell F300E
You need to replace the power supply of the unit, Contact your heating and cooling contractor for service on the unit.
Oct 06, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Can't get the Honeywell F300e EAC back together.
there is a plastic cell key that keeps you from putting the cells in backwards. Simply reverse the cells and they should slide in fine.
I/O is the power switch, I think O is off.
Jul 18, 2008 | Honeywell Enviracaire Elite F300E-1019 Air...
Air Purifiers Logo
102 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
