Question about Philips 32PW6006 32" TV
Philips model: 32PW9523/75
I have this model tv with no manaul or remote. Is it possible to programme
tv, when i turn it on there is a blue screen and no sound. I plugged a dvd player in and all worked well, my only problem is i have no network stations. Any help would be much appreciated.
Thanking you all
Tazman
  • tazmann Jan 07, 2008
    Thanks short_berty, i got hold of a universal remote but the tv is no good. tried to programme it but the screen contorted and blank out, now its off to the tip.. :-(
Purchase a FREEVIEW set top box (from £9.99). You then do not use the TV tuner and you have many more channels in higher quality to boot!
Posted on Apr 15, 2008
Try running it from the DVD by tuning that to stations. I don't bother to tune my TV as DVD/VCR combo has a better tuner
Posted on Jan 30, 2008
    Problem Solver:
  • 12 Answers
Buy a 1 for all remote quite easy to get hold and not too expensive!
Posted on Dec 24, 2007
Need the code to turn on my TV signature 2000 Philips remote sru3004wm/17 or send me a list for other remotes
If your Philips remote is programmable, turn on the TV and use CODE SEARCH-TV to find something that turns it off. Press ENTER or SAVE to save the code in memory.
Aug 20, 2016 | Philips Televison & Video
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
I have a panasonic remote control. How do I program it to control Philips flat screen tv
U can do so only if it is programmable and you have the codes for the philips set.
Get the remote manual for the definitive word.
Nov 08, 2015 | Philips Televison & Video
Philips tv digital disappeared
There may be a firmware upgrade needed here--ask Philips what is available for this model.
Jun 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
Have a sony universal remote model RM-V401 trying to set code for a phillips tv
Procedure to programme Sony universal remote RM-V401 to philips TV are
1. Turn on the component to be programmed.
2. On the remote control, press the SET button.
3. Press the appropriate component button for the component being set up.
4. Using the number pad, enter the component's manufacturer code.
5. Press the ENT button.
6. Point the remote control at the component.
7. Press the POWER button to verify operation.
Code for philips TV are 011 043 056
Thanx
Aug 06, 2010 | Philips Televison & Video
I need the tv codes to enter in my remote i have a sony tv and my remote model is mru1400
Please go to below website you can get the codes to programme out remote.
Please follow the below instruction.
1.Location
2.Select your remote
3.On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
4.Select the device you need to programme and the make of the device you will get the codes.
Thanx
Jul 25, 2010 | Philips Magnavox MRU1400 Universal remote...
Philips 42pfl7762D-lcd blue screen, remote control
Hi! I have the probably same problem (since today) - all I know is that it is because the TV is set to digital instead of analogue, and it won't allow me to put it back into analogue mode - when I try that, i get the cross you mentioned. The strange thing is, that there are no menus visible at all. But the volume and screen output format buttons are workijng and show on the TV. Otherwise the screen is blue. Any solutions?
May 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
Philips TV stuck on the blue language selection screen.
unplug the TV from the wall outlet for two minutes, then try again
Nov 04, 2008 | Philips 32PT5441/37 32" TV
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips model 34pw850h37f
Did you get the remote control with it? i have the same model AV2 if jsut one of likr 4 or 5 inputs for this model, if you have cable signal hooked up, use the AV button on the remote to toggle between all of them, Remotes for this model are available too, Just google.com the model number of TV
Picture is great my me
Nov 08, 2007 | Philips TV Tuner Video Capture PCI Card -...
Philips 32PW6006 32" TV Logo
211 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
