Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
WD440 conditioner inlet /outlet appears blocked
The conditioner is left sitting in the tray after a wash unable to trace route of problem. Any advice gratefully received
    Problem Solver:
  • 9 Answers
There is a tube into the drum, below the soap tray that lines up with the hole in the conditioner part. Make sure this tube is not blocked
Posted on Feb 29, 2008
    Problem Solver:
  • 7 Answers
The most common cause of this problem is a faulty design of the detergent tray, the conditioner works on a syphon system after you feel it up a little bit water is added to it to make the syphon action, either the little wholes above the soap tray are blocked or the soap tray may need cleaning
Posted on Jan 30, 2008
Water coming out of soap tray and running down the front of the machine
Your soap tray and/or inlet is probably blocked with undissolved powder. Remove the tray and clean it. Also clean the inlet tube from the tray into the washing machine with hot water.
I, personally don't like soap powder and use a liquid or tablets because washers nowadays tend to use cold water only so doesn't fully dissolve the powder. Also the outlet to drain gets blocked along with the underground pipe to the mains sewage.
Sep 25, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint wd440 just fills and drains does not move on from wash cycle
it ran for two hours but where did the water go? if it was not cutting off water then u most likely need to replace the water inlet value
Apr 07, 2014 | Washing Machines
The tray for conditioner blocked so always have residue conditioner left with water in it, leading to the right amount of conditioner unable to reach to it's optimum effect. I have tried to take out the...
Here are a few things to try in the order I would try them...
Very hot like boiling water....with white vinegar mix with it...
Hot water and CLR...
Goo Gone...
Alcohol...
Of course make sure to run a wash cycle after cleaning to make sure everything is cleaned out before doing a regular load of wash..
heatman101
Mar 13, 2011 | Siemens Washing Machines
Hi there I have a Hotpoint WF541 washing machine. It has worked fine for 2 years, but now leaks a small amount of water from the soap dispenser down the front of the machine onto the floor. If...
Hi Sheena from retired Englishman in SW France @ 21:51 Sun evening (nothing on TV!)
Sorry if this seems a silly question/answer but have you removed the dispenser completely and ensured that it is not blocked anywhere, especially the conditioner/softener drawer area? Normally the pre-wash and wash powders sit in open ended trays to drop straight into the drum but the conditioner does not. It is not allowed out until the right time- it has to be flushed/siphoned out by the water feed. A common problem is that the tube/pipe which is in this tray down which it siphons is blocked- possible by a mix of powder and conditioner. It is easy to accidentally let the powder spill into it when filling.
My advice is to pull the drawer completely out and give it a good clean out, especially the conditioner bit!
Dispensers are removed either by pulling almost all of the way out then 1) pressing down on the lip at the rear to clear or 2) releasing the clip underneath the dispenser or 3) by lifting upwards just as you are pulling it out, whichever is the way for your machine.
Hope this cures the leaking!
Best of luck,
John C
Feb 06, 2011 | Washing Machines
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
Hotpoint aquarius wd440 confusion over washing machine pipes
Hi is there another valve? If so then you can connect them by a Y piece. Problem solved.....
Feb 26, 2009 | Washing Machines
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
My bosch classix washing machine is not dispensing the fabric conditioner properly. Often the fabric conditioner is left in the dispenser unused, just now it went in with the washing powder. It has...
The water going in to the dispenser is blocked by sludge.
Remove the dipenser tray.
Look up inside the tray hole, at the 'roof' of the tray hole, and there are four holes (square on my machine) where the water flows in - in the middle of the 'roof'. These will be blocked with sludge. Try to poke them clear with a nylon tie or plastic coated wire - should go in a few inches.
It worked for me.
Aug 06, 2008 | Washing Machines
Hotpoint WMA36 Washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2008 | Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
137 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
