Question about LaCie (300770) 250 GB Hard Drive
I have 2 LaCie drives. One a 250 and a 360. I think I may have used the wrong power source at some point. The light comes on but there's no spinning our power up. I'd like to recover files. Any hope? thx
  • 1 more comment
  • monet_morgan Sep 25, 2009
    Hi Bob,
    I have a mac and these LaCie's are 800 firewire or 400 or usb. Not sure if your info applies for a mac user.
    anything else to try?
    thx-m
    I'm use a mac and have 2 LaCie external drives (not very old) that I think I used the wrong power supply. The lights come on but no fan sound or spinning noise. They are a 250 and I think a 360.
    Do I need a PC or is my mac fine? And what it the adapter?
    thx
    President:
  • 1,653 Answers
If you remove the drives from the cases then you can connect them via a USB /IDE / SATA adapter to your PC. This is self powering and will allow you full access to the drive so you can retrieve your files. The adpaters a freeely available at most PC stores or via eBay for a few $$ /££/ Euros. I have two fo these and rthey work without any problems.
Posted on Sep 25, 2009
  • 3,153 Answers
There is hope for you.
Be careful as hard drives are just that ! They are not flash drives so should be treated with care, no bumps, knocks etc.
It is pretty common for this to happen
Your best bet is to remove the drive from its enclosure and connect it directly to a suitable PC. If the PC is new enough it should have both SATA and IDE connections.
You will need a suitable cable or as a temporary measure you could disconnect a CD ROM drive if it is an IDE connection and use that.
Only do the connections with the PC off !
It may take a little longer to boot the PC in most cases that is normal.
You may also have to check the BIOS to make sure it can see the drive but that is not always the case if you have a SATA card installed.
When you have finished connecting boot the PC.
If all goes well you will be able to see the drive and recover data.
In fact if you can see the drive and get at the information you may want to stop there for a moment.
The fact that you can get at it would indicate that just the enclosure is damaged !
That is a big plus as enclosures are pretty cheap and you can install the drive in a new one and carry on as if it never happened (Phewww)
If however you can see or use the drive at all then the news is not good i am afraid.
Hope its the first case and not the second.
Posted on Sep 24, 2009
  • Project NOMAD
    Project NOMAD Sep 25, 2009
    My Lacies are also usb, firewire and sata
    Had a couple of issues with a cheaper firewire cards AND driver issues.
    Also had a few that didnt travel well and internal connections became loose so thats another area you may want to look at.
Power Light comes on, no function what so ever
Check to make sure that the FireWire or USB cables are
correctly attached and firmly seated in both the drive and
computer's FireWire or USB ports. Disconnect them, wait 30
seconds, and reconnect them. If the drive is still not
recognized, restart your computer and try again. If they are
correctly connected and your drive still does not power on,
trying using the optional power sharing cable, described in
section 2.3 Connecting the Optional Power Supply of the LaCie Mobile Hard Drive User Manual.
Feb 17, 2013 | LaCie Computers & Internet
I think I've plugged in the wrong power adapter. Now, once connected, my Lacie makes one whirring noise and fizzles out.
If the wrong power adapter was plugged in the electronic circuitry has been damaged. The only option is to replace the whole hard drive system.
Sep 18, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My lacie hard drive is not spinning up. the light
if still in warrenty return to reseller for replacement but if outta warrenty open it up and try the hard drive in a pc and see if it works ok if it does u just need a replacement external caddy which can be found quite cheaply on most auction websites ;)
Mar 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie d2 120Gb Firewire 400 won't start/spin
What you have is a common hard drive in an enclosure, check eBay or OWC (google it) and get an enclosure for the drive (I would take the drive out first and make sure it is ata not a newer sata, other world computing will reply to an email and I have used them in the UK and Canada, they are in the USA) the enclosure should be cheap ($20 or so)
Apr 18, 2009 | LaCie d2 (300507) 120 GB Hard Drive
My mac is not recognizing my Lacie 1 TB, it started a week ago. It used to work fine for 2 months or so. I got this Lacie less than 3 months ago. I have fully stored my all my music there, but now I can t...
I had the same issue -- turned out that power supply was going bad so the drive wouldn't spin up all the way; this could explain the strange noises you're hearing. I put in a support ticket with LaCie at their website and they sent me a new power supply at no charge (I was within the warranty period, I think).
Mar 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Hi, my Lacie seems ti=o have stopped working. Power seems to go into it as the power light comes on (amber) but then it beeps and the seems as if it does not spin
this is a common issue however its bad news, your inter motor stopt working and there's no point repairing it and you cant get your data back either
Mar 06, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Drive is on, won't mount, buzzing
It does not sound good, the hard drive may be faulty or even the drive enclosure could be faulty.
Try thr following:-
1. Take the LaCie drive and connect it to another MAC, if it reads the drive, your in luck.
2. Dismantle the drive case and remove the hard drive and reconnect it again (a few times). The drive may need reseating to make proper electrical connection. Test it in your MAC.
3. The LaCie case could be faulty, remove the drive and insert it into another working LaCie drive case. Test it in your MAC.
4. If the hard drive is faulty, there are hard drive data recovery companies that can retrieve your data, but it will cost you an arm and a leg for their service.
In future I would not rely on a single device for backing up important data. You should get 2 LaCie drives or a dat tape drive plus a LaCie drive and/or burn the data on BlueRay disks.
You should also protect your computer and devices against lightning strikes, power outages/blackouts and power surges with an UPS (uninterruptable power supply), especially when you are editing, burning, copying/back up your data.
Jan 15, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie not working
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Nov 02, 2008 | LaCie F.A. Porsche (301177) Hard Drive
LaCie (300770) 250 GB Hard Drive Logo
59 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
