Question about Apple iPod MA446LL/A MP3 Player
Wont update songs
When ever i plug in my ipod to update it updates the first ablout 30 songs and then says error ipod disk has found eroor.........
To reset an iPod with a Click Wheel, including: wont update songs - ipodnano3.jpg icon_ipod_5g.gif ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Dec 20, 2007
I plug my ipod to the stereo but my stereo screen still says discconected
you have to go to the kenwood site and download the firmware update go to this page http://www.kenwood.com/cs/ce/mm/firmware/2008/eng.html
after you download the file unzip it and burn it with either nero or roxio, as a data file insert the cd on your kvt-512, if it reads DISK ERROR, press the reset button on the front of the stereo, once the screen comes back up select the DVD function, the system update should start from there. let it finish once it does then you'll be able to plug in your ipod. oh and ofcourse for this you should know that you need the ipod adapter, depending on what you want to do with it for instance i have the KCA-iP300V which allows me to view videos from my ipod as well.
Jan 27, 2010 | Kenwood KVT-512 Car DVD Player
Wont sync to my computer,already synced to another.can i sync without erasing?
Done try to sync...... u see the options when u connet ipod....just put the ipod in to disc mode. and then just drag mp3 tracks u want to load on your ipod......... doing sync will just update from itunes which ever songs listed....... its better to drag and load songs in your ipod..... for that u need to put ipod in to disk mode.... hope this help u.
Jul 20, 2009 | Apple iPod nano
160G problem
When you try to sync files to any iPod in iTunes on a Mac or Windows computer, you might see the following -69 error message:
"Attempting to copy to the disk failed. An unknown error occurred (-69)"This error occurs when iTunes tries to send files to your iPod, but a file (or files) is unusable (something is wrong with it).
To figure out which file (or files) is causing the error, update to the latest version of iTunes and then do this:
  1. Control-click (Mac) or right-click (Windows) on your iPod icon in the iTunes Source pane, then choose Sync Songs from the shortcut menu.
  2. Watch the display at the top of the iTunes window while your iPod is being updated. The name of the problematic file should appear in the display right before the error appears.Then remove the bad file from the list of songs to be synced to your iPod:
  3. Select the iPod in the iTunes Source pane.
  4. Click the Settings tab.
  5. Select the "Only sync checked items" checkbox (please note that this checkbox is only available for an iPod configured to update automatically).
  6. Select the appropriate item under Library in the sidebar and find the bad file in the list. (For example, if the file in question was a song you would select Music in the iTunes Source pane. If it were a video you would select Movies or TV Shows in the sidebar.)
  7. Deselect the checkbox next to the file name.
  8. Repeat steps 1 and 2 to update your iPod. If you have multiple problematic files in your iTunes library, you may need to repeat the other steps to remove them too.
To prevent future issues, you should delete the unusable files from your iTunes library, then restore them from a backup or reimport them from a CD.
If you're not able to isolate to any single file or if another iPod works with the same songs, then disconnect any other devices connected to USB or FireWire and try again. If the issue continues, then then try resetting your iPod. If the issue continues, then restore your iPod.
Dec 08, 2008 | Microsoft Windows Vista Home Premium with...
Error-69 with iTunes
Summary When you try to sync files to any iPod in iTunes on a Mac or Windows computer, you might see the following -69 error message:
"Attempting to copy to the disk failed. An unknown error occurred (-69)" Products Affected iTunes, iPod
  2. Watch the display at the top of the iTunes window while your iPod is being updated. The name of the problematic file should appear in the display right before the error appears. Then remove the bad file from the list of songs to be synced to your iPod.
Cyber kaka
Ipod security code
There is only one way - and it will erase all your songs:
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work
with, your iPod nano automatically unlocks. If the computer authorized to work with
your iPod nano is unavailable, you can connect iPod nano to another computer and
use iPod Updater to restore your iPod software. See the next section for more
information.
If you want to change the screen lock combination and you can’t remember the
current combination, you must restore the iPod software, and then set a new
combination.
Updating and Restoring iPod Software
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
â If you choose to update, the software is updated, but your settings and songs are not
affected.
â If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
May 26, 2008 | Apple iPod nano
IPod won't play after I updated it
follow Apple's 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
May 10, 2008 | Apple iPod shuffle 3rd Generation MP3...
Restoring Ipod issue
hi dear
Following is list of iPod and iTunes Error messages or Alert messages you may come across while trying to open or install iTunes, update, sync or restore iPod, making a purchase from iTunes Store, or perform any other activity in your iPod/iTunes:
  1. "Unable to Check for Purchased Music because an error occurred (-5000 error)."
  2. "Error (-35)"
  3. "There was an error in the iTunes Store. Please try again later."
  4. "-5000" and "-35"
  5. “Error 1415” “Error 208” “Error 1418” “Error 1413” “Error 1427” “Error 200” “Error 1402” “Error 50” “Error 1406” “Error 1407” “Error 1428” “Error 1417” “Error 60” “Error 42” “Error 48” “Error 39” “Error 1417” “Error 53” “Error 69” “Error 50” “Error 3221””Error 2738” “Error1921” “Error 1607” “Error 5000” “Error 9006” “Error 9800” “Error 9814” “Error 9815”
  6. "Failed to locate Supported File Types or There Are No Photos Found on this Device"
  7. "the iPod ** cannot be updated, the required folder cannot be found"
  8. "Cannot connect to the iTunes Store. An unknown error has occurred”
  9. “Disk is locked”
  10. "iTunes folder cannot be found"
  11. “Disk cannot be read from or written to”
  12. “Firmware update failure”
  13. “Drive not formatted”
  14. "The iPod "username's iPod cannot be updated. The required folder cannot be found"
  15. "Folder cannot be found or created"
  16. “Attempting to copy to the disk [iPod name] failed. The disk could not be read from or written to.”
  17. "Sync failed: unknown error (-124)"
  18. "iPod cannot be synced: required folder cannot be found"
  19. “iPod Service Error”
  20. Cannot Import to Itunes - error 2002”
  21. "Attempting to copy to the disk (iPod name) failed. The disk could not be read from or written to"
  22. “The iPod "Customer's iPod" could not be restored. An unknown error occurred (1418)”
  23. "The iPod "Customer's iPod" cannot be updated. An unknown error occurred (-50)"
  24. “iTunesSetup.exe is not a "valid Win32 application"
  25. "Internal manager error”
  26. “iTunes 7.02 not a valid Win32 application”
  27. "itunes.exe - Corrupt File"
  28. "An Unknown Error occurred (-39)"
  29. "Could not complete your iTunes Store request. The store may be busy. Check your Internet connection or try again later."
  30. "There was an error downloading your purchased music. An unknown error occurred (-50)."
  31. "-9800, -9815, -9814"
  32. "Unable to Check for Purchased Music because an error occurred (-5000 error)."
  33. "There was an error in the iTunes Store. Please try again later."
If you come across any one of the above Error or Alert messages, then either your iPod/iTunes has gone corrupted and your iPod may be in for a crash or maybe you’re already facing an iPod crash. iPod might crash or get corrupt due to any of the reasons from hardware failure to corrupt iPod cache to damaged Files or to damaged disk structure.
You must be cautious and try to recover lost data from your iPod from reliable and proved software which is non-destructive and can recover all data—damaged or deleted. Any compromise can thwart your recovery process. Try Stellar Phoenix iPod Recovery Software.
from this site
http://www.ipoddatarecovery.net/download-ipod-recovery-software.php
oke
Mar 22, 2008 | Apple iPod classic MP3 Player
Not able to put in songs
I cant help you with trying to fix the format problem but i would recommend puttingall your itune songs onto a disk and then try to fiddle around with it. You wont have to worry as much. Sorry I'm not much of ahelp though.
Aug 21, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
81 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
