Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Electrolux ice maker is not making ice. Water is
Electrolux refrigerator is not making ice. Water is still dispensing and the icemaker function is reading ON in the visual display screen. Ice tray is empty.
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
  • 833 Answers
SOURCE: Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Posted on Dec 24, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Model GS6NBEXRL01 ice maker not making ice
Most likely the water control valve on back of the refrigerator near floor or the thermostat inside the ice maker is defective. You can fill the ice maker with water from tap and see if it cycles one time or you can check the control valve solenoid that feeds water to the ice maker. Click on link below and then paste your model number in model search feature. That takes you to a page with breakdown photos of the parts I mentioned. On the left of your screen click on photo # 12. If you need help with this I am here, just let me know, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
woodchuck789
  • 4059 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
    Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
    ? 2:47
    https://www.youtube.com/watch?v=aXIX73EI1Z4
    May 15, 2012 - Uploaded by RepairClinic.com
    This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
    Refrigerator Ice And Water Dispenser Not Working - Repair ...
    www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
    How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
    Nov 18, 2015 | Refrigerators
    Ice maker leaking
    Hello Friend, thank you for your inquiry! I understand that water is
    leaking from the ice maker of your Electrolux refrigerator; however please help me understand if you are referring to the ice/water dispenser (filter) or actual icemaker? With this material I can better address the issue at hand. Thank you! - Z
    Jul 14, 2014 | Electrolux Refrigerators
    Ice maker
    Before going to buy any parts directly.
    Go through this troubleshooting help links.
    This is list of refrigerator problems, which is normally faced in refrigerator.
    You can go through the details, by clicking the link below:---
    Refrigerator is not cooling properly?
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    Both refrigerator and freezer not cooling properly in refrigerator?
    http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
    The ice maker not working: ---
    http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
    Compressor not running on refrigerator?
    http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
    Water dispenser not working on refrigerator?
    http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
    Ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
    Water Overflows in Ice maker and freezes inside?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
    How to replace Ice maker assembly?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
    other ice maker related issues and solutions:---
    Ice maker dispensing ice with black or white plastic pieces in ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
    After replacing ice maker assembly, ice is not getting made?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
    Ice maker is leaking water and causing the ice to freeze?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
    Ice maker is noisy and not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
    Refrigerator ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
    Ice maker leaks water into ice bin causing a glob of ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
    Amana Refrigerator leaking water from ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
    Ice maker leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
    Ice maker is dumping the ice cubes out before frozen solid.
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
    Water overflowing ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
    Ice cube is getting stuck up hard in ice maker
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
    Icemaker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
    Quit making ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
    Water leaking into ice tray, frozen glob of ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
    Not making ice, and water leaking in freezer?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
    The ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
    Ice maker not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
    Ice maker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
    Ice maker dispensing black pieces of plastic in the ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
    Replaced Ice maker but its still not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
    Ice maker leaked creating an ice block?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
    Ice tray leaked?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
    Ice maker stopped functioning?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
    Ice maker stop working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
    Ice maker failed
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
    Old ice maker stopped working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
    Old ice maker started leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
    Ice maker not working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
    Ice maker overfills and cause water to flow into ice dispenser and freezes?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
    Ice maker didn't make ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
    Ice maker was leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
    Ice maker was leaking after it filled up with water?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
    These will help.
    Thanks,.
    Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
    Jennair jcd2289 side-by-side does not make ice
    If you are getting water from the dispenser, then the water valve is good. The icemaker will need to be replaced since when the icemaker cycles and empties the ice tray, it should call for the water to refill and it is not doing so. Here is a link to the replacement icemaker.
    Oct 16, 2012 | Refrigerators
    Ice maker stopped dispensing
    Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
    Aug 05, 2012 | Maytag Refrigerators
    my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
    Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
    I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
    i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
    Mar 31, 2011 | Refrigerators
    My icemaker has stopped receiving water
    it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
    you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
    May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
    Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
    2,000 people viewed this question
    Top Frigidaire Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Steve
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
