Question about Rangemaster Elan 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Elan 1100 I would like to know how to get the glass covers off the oven bulb sso I can change them as they have blown.
    Problem Solver:
  • 22 Answers
I had a similar problem with my Rangemaster Toledo 110. The glass cover would move slightly but would stop as if being held by something. I went to the Rangemaster website and the checked the users manual which suggested it was a simple operation of turning anticlockwise. Eventually I got a pair of vice grips and opened them to their widest and clamped them round the glass. The slightest of pressure and the glass moved past the stop point and off!! I've replaced the bulb and put the glass back on only hand tight and in anticipation I've loosened the glass cover in the other oven - just in case!
Posted on Sep 07, 2008
WE HAVE A NEWHOME 550WL DL GAS COOKER. I DONT KNOW HOW TO TAKE THE GLASS OFF TO CHANGE THE BULB. THE GLASS IS SQUARISH, BUT THERE ARE NO SCREWS.
Taken from the User Manual.
Remove the oven shelves. Remove the loose oven back by unscrewing the 4 securing screws (one at each corner) and remove (Where fitted). Unscrew the lens cover by turning anticlockwise. Remove the bulb and replace. Replace the lens cover and oven back.
Jan 18, 2018 | Kitchen Ranges
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Aug 23, 2015 | Stoves Premier 720EMa Electric Double Oven
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
HOW TO REPLACE THE LIGHT BULB IN MY OVEN
Oven Lighting
Warning: Risk of electric shock! Prior to changing the oven light bulb:
- Switch off the oven!
- Disconnect from the electricity supply.
Changing the oven light bulb/cleaning the glass cover
1.Remove the glass cover by turning it anti-clockwise and then clean it.
2.If necessary: replace with 25 watt, 230 V, 300 °C heat-resistant oven lighting.
3.Refit the glass cover.
24472822-skr3uzd4ii43xzwyhmpsswym-3-0.jpg Dado
May 21, 2014 | Electrolux EOB5665G Ultrafan Electric...
I have a siemens electric oven. The bulb has blown and is encased in a glass cover. The intructions say to turn anti-clockwise to remove the cover, but it just won't budge. Ant ideas how I may free it?
The bulb cover is probably gummed up with solidified oven grease and therefore stuck.
The only thing you can try is to turn the power off and spray around the edge of the glass with oven cleaner and leave for a couple of hours in the hope that it will soften and allow you to unscrew it.
Be careful not to get the spray cleaner on to the heating elements.
Dec 17, 2010 | Ovens
How to replace a blown bulb
  • check the size of the bulb required before you buy a replacement bulb. Most use a 40 watt appliance bulb. I
  • Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Open the oven door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back then Gently remove either the wire clip or ring. Since the cover is most likely glass, be careful then Unscrew the entire glass cover similar to a jar lid in older versions of ovens. repeat process if there is more than one bulb..hope this helps pls do let me know
  • Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    How do I change the bulb in an Inglis oven. Can't
    Normally the cover will have an anticlockwise turn thread. Twist the glass cover anti clockwise and it should unscrew.
    Jan 04, 2010 | Ovens
    Unable to remove the glass cover to change the light bulb in oven
    I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
    Jan 12, 2009 | Ovens
    Oven bulb
    i have a ge profile double oven and the glass cover on the top convection oven is held in place by grooves that latch onto the glass dome cover. Just turn the dome so that the handles on the glass dome cover are exposed. I used a flashlight and a screwdriver to push the dome to one side.
    Dec 25, 2007 | GE Profile JTP56 Electric Double Oven
    Oven
    Pry back the bulb glass cover wire spring and remove glass cover. Use heavy rubber gloves or a plastic bottle opener(piece of serrated soft plastic/rubber) and unscrew counterclockwise.
    Mar 05, 2007 | Whirlpool GBS277PR Electric Single Oven
    Rangemaster Elan 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
    342 people viewed this question
    Top Rangemaster Kitchen Ranges Experts
    Ismael Rodriguez...
    Charles T Nevin
    Charles T Nevin
    Paul Carew
    Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
