Question about HP LaserJet 3390 All-In-One Printer
Trying to set up fax to print when sending fax
How do I set up fax to print a receipt after sending fax?
  • 38 Answers
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
● Every fax error (the factory-set default)
● Send fax error
● Receive fax error
● Every fax
● Send fax only
● Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
Posted on Nov 05, 2009
How do I set automatic fax receipt?
If you got a satisfactory solution to the fax receipt issue, I would surely appreciate your sharing it with me. I don't think that any HP all-in-ones will give you a receipt from the recipient. I need this too.
Maybe I will reinstall Win Fax
Jun 02, 2010 | HP LaserJet 3390 All-in-One Multifunction...
RECEIPT FOR SENT FAX
Pree menu/set then numbers 2, 4, 1. Chose on with the up and down arrows then press menu/set.
May 28, 2010 | Brother MFC 420CN All-In-One InkJet...
Our fax keeps sending black pages on the receipt
You have a bad SCANNER BLOCK...expensive repair.
May 12, 2010 | Brother IntelliFax-4100e Fax
Q. 1 - When I try to send a fax I get an error message that says: Fax Send Report is set to Off Q. 2 - I have an 1/2 inch black line down one side of any copy I try to make.
1. Usually a "fax send report" just means that you will not receive a "receipt" or "confirmation" that the fax was successfully sent. Changing the setting to off is pretty much just saving you ink & paper. When my fax machine report is set to off, I only receive a receipt if the fax was unsuccessful. However, all fax machines are different and have a mind of their own...so your best bet it to refer to the owner's manual or call the company where it came from.
2. The only thing I can think of is maybe you need to replace the plexi-glass on the copier or do an internal wipe of the underside of the glass. Sometimes the ink can smear from underneath when faxed papers get jammed or printed.
Sep 04, 2009 | HP Office Equipment & Supplies
Entering my own phone number to a fax machine
press help key then print your setting phone no or change
Jun 28, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
Need printed confirmation fax receipts
I had the same problem with my 6210. A different machine, but this may be worth a try. You need to go to the general setup, rather than the fax menu on the keypad. Two pushes of the button takes you to "print reports". Press OK and you go to "Fax Report Setup", OK again gives you "Print Report". You then can toggle with the arrows for the various options. In this case press OK when you are on "sent faxes"
Apr 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Faxes receipt
Set fax to MANUAL Mode.
print out a Fax parameter sheet...Function 64 set
change the parameter in 74 set
May 13, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
FAX CONFIRMATION
-press menu
-press 3, then press 6 to select Print Report
Apr 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paper feeding when printing recieved faxes
If this is primarily happening with receipts from one sending fax machine, the most likely cause is that the sending machine is transmitting an end code that causes this page to print.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Oct 26, 2007 | Canon FAX-JX200
HP LaserJet 3390 All-In-One Printer Logo
267 people viewed this question
Seeker5211
Seeker5211
