Question about Sony Ericsson w580i Cellular Phone
W580i phone volume always goes to maximum and drains battery . Lowering the volume only causes it to raise to the highest level on it's own. This problem is affecting battery life. I have to recharge daily.
HOW DO INCREASE RINGER SOUND
Hi Melvin
Majority of phones... when you are in the PHONE screen , just
Press the "+" button on the upper left side of the Phone. The Ringer screen will appear, superimposed on top of the screen you most recently used. Click the "+" button one time to raise the volume one level. Continue clicking the "+" button to raise the ringer volume higher until its at the maximum level...or however loud you want it.
Apr 28, 2016 | Cell Phones
Tip
Tips & Review on Nokia 5300 XpressMusic
Nokia 5300 is a great music phone,but it can be regrated on that the battery life is so short.So I've come up with this tips and tricks that can help you save some juice out of your phone.Love the loudspeaker but don’t abuse it so much it might become unfunctional.Don’t set the volume to the maximum level when playing through the loudspeaker.I found the radio better and clearer when playing through the loudspeaker than the music player because the loudspeaker omits more treble than the bass.
Camera Tips:
1. Always set the NIGHT MODE option especially on night shots
2. Set the White Balance to Daylight – When outdoors (Day) Fluorescent – When indoors
3. For acceptable shots, set the resolution to 800 x 600.
NOTE: Using the camera will put up a big drain on your battery.
Battery Tip:
- Don’t always use the camera. Only when needed.
- Set Packet Data Connection to When Needed. Setting can be found on Settings>Connectivity>Packet Data
- Always turn on the Power Saver Feature.
- Turn off your Bluetooth when not in use.
- Turn off screensavers (These are only battery wasters)
- Always make sure that the phone has adequate signal. (If the phone is searching for signals, it drains a big part of the battery)
- I know its fun to play games, but it can decrease your battery so fast.
- The best of all,carry an extra battery if you’re a heavy user.
I think this tip can be helpful. Thank you Everyone.
on Sep 22, 2009 | Nokia 5310 Cellular Phone
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
Volume goes back to low on mitel 5000 ip phone
If you raise the handset volume to the maximum level it will revert to the default after the call. To save the volume at current level stop at level 10 instead of 11 and the volume level should hold.
Feb 10, 2014 | Mitel 5330 IP Phone
Need help with magnavox TV volume control
The volume control logic circuit inside the TV [circuit board] is faulty. Contact any experienced service technician. This is not a user repairable fault.
Sep 21, 2012 | Philips Magnavox 13MT143S 13" TV
I have a 6th generation iPod Nano. This is the fifth one I've had and they all have had the same problem. At some point (usually after I've had it about a month) it starts to turn the volume down...
The only thing I can think of is that maximum limit has been set low and is somehow lowering itself. To set the maximum limit
On the home screen, tap settings
Tap Music, then tap Volume Limit
The volume limit control will then come up to raise the limit move the slider all the way to the right.
If you want to stop the volume limit moving you can put in a passcode by clicking on the Lock Volume Limit and entering a passcode (I'd just put in 1234, so you can remember it easily(
Hope this helps.
Sep 07, 2011 | Apple iPod nano 3rd Generation
Hello, I'm trying to increase the volume on some phones mitel 5220 and 5224, but it only goes to 6. I need the volume level to go to 10. Do you have any ideas? Firmware is 07.02.00.04 Thank you
The ADA compliance requires that the phone when set to the highest volume level will revert back to factory default setting for the next call. This is a safety feature to prevent one's hearing aid from being blown up by a loud caller.
If you turn the volume up to 9, and leave it there, it will stay at 9. If you turn it up to 10, it will always revert back to default.
I hope this helps,
Mark
Feb 08, 2011 | Mitel 5220 IP Phone
Frigidaire glws1233as1 water runs continually. seems like a valve is stuck open or something. water is draining as fast as it is filling up.
your drain hose or drain is too low causing water to siphon from the tub as fast as it runs in. raise or loop the drain hose higher than the highest level of the tub.
May 28, 2010 | Washing Machines
Why do the volume numbers on old receivers start
This type of calibartion is known as a logarithmic scale.
The numbers refer to decibels below the maximum output of the amplifier section of the reciever, or decibels of attenuation (making smaller/quieter).
Without going through logarithim theorey, the logarithim (base 10) of 1 is 0. So if 1 is the maximum output of the amp, as you turn the knob down from maximum you are adding more and more attentuation to the output (relative to maximum) and so the loudness of what you hear goes down, even though the number on the scale is going up !
Most peolpe associate decibels with sound levels, but anything can be measured in decibels, so long as there is soemthing to reference it against.
Nov 04, 2009 | Pioneer VSX-D409
Washer less than a year old. Top loading. Will
Have you moved recently, or moved the washer for any reason?
Two things can usually cause that.
First, Some part of the drain hose must always be higher than the highest possible water level in the machine. Remember that water flows downhill. If all the hose is lower then the highest possible water level the machine can never fill since water will drain out hose. So, raise the hose higher than the flat top of the washer and try again.
2A, Inserting the drain hose too far into the house drain. or 2B, sealing out ALL air in the drain line by using a hose too tight in the drain pipe or taping the drain pipe tightly with the drain hose in it can both create a vacuum in the drain line which will actually **** out all the water in the tub. This can be tested by pulling the drain all the way out and aiming it into the tub as you try it. Good Luck.
Aug 23, 2009 | Maytag Washing Machines
Sony Ericsson w580i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
