Question about ViewSonic E55 15" CRT Monitor
Display Problem H V Frequency Over Range
  • bud123456 Aug 26, 2008
    monitor says frequency out of range computer will not show anything else
  • Anonymous Apr 28, 2009
    after connecting T.V.Tuner card "H.V. Frequency Over Range
  • 151 Answers
You have to run your system on other monitor and set monitor refresh rate at 60herzby desk top properties option setting and advanced.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Mar 16, 2008
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
Ps3 frequency out of range
This model will only support 1080i. What you need to do is go into the display settings on your PS3 and set the max resolution that your TV will support to "1080i" That should get you going!
May 19, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
In the middle of my screen a blue box is showing and in it this reads OUT OF RANGE H. FREQUENCY 68.7 KHz V. FREQUENCY 85.0Hz What does this mean and how can I fix it this was a gift...
That message appears when the Windoze display settings exceed the monitor capabilities. If you will boot into windoze safe mode (F8 at boot) and correct the display settings, the message should clear at the next boot. Afterwards you can right click on the desktop and access the display settings to make final adjustments.
In your case, the refresh rate (V Frequency) should not exceed 70 Hz
Nov 23, 2009 | Envision H22W 22" Monitor
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
"out of frequency range" message nothing works
Try booting to the ENABLE VGA mode off the F8 menu if you can get to the desktop and then you can go to display properties and see if you can reset the resolution to normal. If no go, try updating the video driver
Oct 02, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
View sonic -E70fB monitor displaying H.V frequency out of range when ever i play a game on the monitor screen it is displaying h.v frequency out of range....how to solve this problem
view sonic -E70fB monitor displaying H.V frequency out of range
Jun 06, 2009 | ViewSonic G70F 17'' Monitor + Wyse Winterm...
My scanner is locked on hypersearch. How do I get
Answer: Hypersearch can only be turned on and off through a limit or direct search. To turn it off, you should do the following: Through Limit Search:
  1. Press PROG, then LIMIT (SRC). Lo and 29.000 MHz appear. 29.000 MHz is the low end of the scanner's range.
  2. Enter the frequency that is the lower limit of the range you want to search (including the decimal point), then press E (SVC).
  3. Press LIMIT (SRC). Hi and 1300.00 MHz appear. 1300.000 MHz is the upper limit of the scanner's range.
  4. Enter the frequency that is the upper limit of the range you want to search (including the decimal point), then press E (SVC) again.
  5. Press \/ to search from the upper to the lower limit or /\ to search from the lower to the upper limit.
  6. While the scanner is searching or is on a transmission, press H/S.
  7. HYPER should disappear from the display.
Through Direct Search:
  1. Press MAN.
  2. Enter the frequency you want to start from using the number keys. (Press . to enter a decimal point). NOTE: To start the search from a frequency already stored in one of your scanner's channels, press MAN or PROG. Then use the number keys to enter the channel number and then press MAN or PROG again. If you enter an invalid frequency, the scanner displays Error. Press MON/CLR (.).
  3. Press \/ to search downward or /\ to search upward from the selected frequency. -d-, SEARCH, and either \/ or /\ appear.
  4. While the scanner is searching or is on a transmission, press H/S.
  5. HYPER should disappear from the display.
May 15, 2009 | Radio Shack Pro-94 Scanner
Out of range frequency
Lower the PC display resolution to a lower refresh rate.
Jan 09, 2009 | LG 42LC2D 42 in. LCD HDTV
ViewSonic E55 15" CRT Monitor Logo
82 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
