Question about Cell Phones
My iphone has just turned itself off and I can not turn it back on? It had half power in its batt and I had no other problems. I have taken out the simm and put it back in. I have connected it to my mac...nothing,I have charged it...nothing????
My iPhone is Stuck on....large screen. Will not unlock IPhone 5
Try resetting phone...hold power on button with volume up and home button together for ten seconds or until screen goes off ...restart phone.
Feb 11, 2015 | Apple iPhone 5
When I turn the power on, green power light comes on, lens comes out half way but then freezes and green light goes off, camera unresponsive. battery is fully charged and I have taken it out and put it...
Hi.
This is a common problem , generally indicated as lens error. The problem is often caused by dirt or dust in the lens gears.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
You can attempt tapping gently the back of the camera while turning the camera on. Sometimes this can help the lens out.
If that does not work, then the lens must be taken apart.
I summarized the problem in this article: Lens Error.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Regards.
Aug 09, 2010 | Canon IXUS 960 IS Digital Camera
IPhone slider won't slide all the way across
I'm having the same issue, have you found any solution?
Apr 30, 2010 | Apple iPhone 3G
IPhone will not turn on. I have tried everything I Think is possible. Home/Power reset mute on and off 4 time all of em! Can anyone tell me what I have to do with this year and a half phone?iphone 3g...
I have seen that happen before, hold the power + home button untill the apple comes on the screen, it may take as long a a minute to a minute and a half.
Mar 20, 2010 | Apple iPhone 3G
My iphone wont turn on past the silver apple logo.
Open up iTunes, connect the iPhone. Hold down the power button for 3 seconds, hold both power button and home button for 10 seconds, release power button while still holding down the home button. This puts your iDevice into DFU mode, so it can be restored using iTunes.
Aug 09, 2009 | Apple iPhone Smartphone
IPhone needs repair/iPhone can't make or receive calls/won't power on
i had the first geniphone and he problem was it was dropped and the screen was disconnected and it was plugged back in and worked fine
May 29, 2009 | Apple iPhone Smartphone
I dropped my digital camera when it was opened and it is jammed open, I had power at first, but then I took the batery out and put it back in and have now power. I cant get it to close. What can I do to...
I have the same problem exactly. After my 3 yr old daughter brought it back to me after she had bounced it off the floor a few times, the lens was half out with the last pic taken on the display. I couldn't do anything so i removed and reinserted the batt and now i have a sticky out lens and no power...
Oct 18, 2006 | Konica Minolta DiMAGE G530 Digital Camera
Cell Phones Logo
181 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
