Question about Sharp AR-M257 Black and White Copier
Error code f2-04 after changing to new toner cartridge
  • 63 Answers
F2 04
  • Identification error
  • Model error
  • Type error
  • Destination error
  • Data abnormality
  • Misc error
It is always recommended to use OEM toner. The toner you need if AR-310NT
Posted on Oct 12, 2009
Konika c 552 error code is 2a21 New release filur. How to solve
Here you go!
Konica Minolta bizhub C3350 Error Codes
Code
2A21
Description
Toner cartridge/C new release failure
The status with the new cartridge is not cleared after the new toner cartridge is set.
Causes
• Toner cartridge/C,M,Y,K • Printer control board (PRCB)
Remedy
1 Check the connector between toner cartridge-relay CN79-EXCB CN4 for proper connection and correct as necessary. - - 2 Clean the connection between the toner cartridge and the machine if dirty. - - 3 Reinstall the toner cartridge 4 Check the harness for proper connection and correct as necessary. - - 5 Check the connector between EXCB CN2-PRCB CN11 for proper connection and correct as necessary. - - 6 Replace the toner cartridge - - 7 Replace PRCB
Anthony
Apr 15, 2018 | Office Equipment & Supplies
Mx2300 write code f2-70 after replacing the black cartridge
F2-70 is indicating an improper toner cartridge K.
If you have just changed the black toner cartridge & the error appeared then the new toner is at fault.
Replace the toner cartridge with another cartridge, turn the machine off & back on & the machine should reset.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Mx-2300n Copier Color Mx2300n...
How can i solve error code f2-04 in sharp 5127
The main reason for the error code is an incorrect toner cartridge being used in the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off 2. Remove the incorrect toner cartridge 2. Unplug the power cable from the wall outlet. 4. Plug the Printer back on 5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
If this resolves the problem good else you will have to replce the carrtridge.
Sep 11, 2011 | Canon imageRUNNER 8500 Copier
Error code F2-04. Have replaced cartridge but to no avail for the Sharp Model # AR 168S Copier.
Try this solution I found on an other site.
In a Sharp MX-M450N copier this is due to improper cartridge.
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
Dec 28, 2009 | Office Equipment & Supplies
E020 01BO What does this error code mean?
E020 indicates a Black Toner malfunction. If you've recently changed the toner and failed to distribute the toner by gently shaking it from side to side, this could be the cause of this error or if the toner is very low it could trigger the same error.
01B0 is a drum error related to your toner error message. If toner cartridge is good, remove the cartridge, clean the drum, replace the cartridge and both errors should clear. A dirty drum will also trigger your 1st error e020.
Nov 16, 2009 | Canon CLC 1120 Color Copier
Error code 54.18
The error code 54.18 means that there was an error with black toner cartridge toner level sensor. Try taking the cartridge out and shake it a little to loosen up the toner inside, make sure all of the cartridge metal electrical contacts are clean and try it again. If it still has a problem you should try a new black toner cartridge. If that doesn't change things then you may need to replace the DC controller.
Sep 09, 2008 | HP LaserJet 3600dn Printer
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
Sharp AR-M257 Black and White Copier Logo
618 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
