Question about Tomtom ONE XL GB Car GPS Receiver
Tomtom xl v9
I press the on button and all i get is a black screen. I can tell the screen is on, cause there is light around the edges. I have remove the applications from my pc and the tomtom several times. But to no avail. It will start is i hold down the on button for 15 sec. I will work find untill i turn it off. Then i gotta do it all over again. What do i do?
5 Suggested Answers
SOURCE: frozen startup screen
jump up and down on it about 27 times sorry 28 and see if that helps, it did me - i then went and bought a MAP
Posted on Dec 26, 2007
SOURCE: tomtom one xl freezing on start up screen
OK... I found an amature solution;
- Do a soft reset of the system, with the paperclip (see tomtom site)
- Put the device on the docking station and connect it to power as well as to your computer. While it's turned off
- Turn on the TOMTOM while connected to the computer
- Start the TOMTOM Home software
- And it made connection again
- Disconnect the device via the software
- Take the device out of the docking station
- Turn it off and on once
This worked for me, my next step would have been the support desk. Grtz Derk
Posted on Jan 22, 2009
  • 171 Answers
SOURCE: My Tomtom XL won't turn on. No reset button apparent
The reset button is on the bottom of your device. On my older model XL it is just above the sd card slot. If you have the newer model XL 330 then you have to hold down the on/off switch for 20 seconds to do a reboot. If you have not used it in a while let it charge for 30 monutes before doing a reset.
Hope this helps
Posted on May 12, 2009
bob_computer
  • 3153 Answers
SOURCE: tomtom xl says no maps available after installing
when your registered it with tom tom they take note of your maps
check your online tom tom account and it should let you re-download your maps.
I you backed it up to your computer you can also restore the maps from there with the tomtom home software
Posted on Aug 22, 2009
Don't know the location of serial #
touch the screen where the gps signal meter is then touch where it says v7.xx v8.xx v9.xx that appears on the new screen then i will give you the serial and version numbers
Feb 15, 2011 | Tomtom ONE XL GB Car GPS Receiver
The green power light on my tomtom XL is on and is fully charged however the screen wont turn on and remains black, it also makes no noise.
First you need to check if the battery is okay, try it on another tom tom gps receiver, if it is working and the screen wont turn on, then it means there is a hardware problem, probably the flexi ribbon that is connected to the screen is either loose or bad, this will require you to disassemble the tom tom and check for the flexi ribbon that connects to the screen, then you resit it or change the ribbon, that should do the job.
You can also try to reset the tom tom first before disassembling it. By pressing and holding the power on/off button for about 15 seconds, if that does not do the job, then you can go ahead and disassemble the tom tom.
Hope this solution helped
Dec 22, 2010 | Tomtom ONE XL-S GPS
One xl freezes on tomtom startup screen
It is because of you just upgrade your device.
Not to worry. If you can't switch on/off, try harder.
Press on/off button for on/off purpose until on/off.
After that, the device works properly.
Jun 21, 2010 | Tomtom ONE XL GPS
Green light is on when plugged into car cigarette lighter but cannot switch it on and the screen remains black
hook it up to the usb cable to your computer for a few hours (but not more then 4 hours) then press and hold the power button for up to 15 seconds.
once you get it started, hook it up to tomtom home and see if it has the latest updates.
if you do not have tomtom home, you can download it HERE
Oct 26, 2009 | Tomtom One XL GPS Receiver
My screen on the tomtom xl won't turn on I have done the reset a few times and still nothing
Hi, press the reset button & keep it pressed whilst pressing the on/off button a number of times.This should wake it up. PS make sure it is charged! Bluey
Jul 30, 2009 | Tomtom ONE XL GPS
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
I have had my tomtom one XL for almost one year. The car adapter (charger) cord went bad and they were backordered on the tomtom website so I purchased a radio shack universal adapter for navigational...
More than likely the generic charger sent more than 5 volts to your tt and burned a few rectifiers. You could try and tell tt the original charger did this but if they say no you are out of luck. You could put it on ebay and get something for it.
Apr 19, 2009 | Tomtom ONE XL GPS
Hi, just bought a one xl, have tried to set up my home address and I pressed a wrong button, Italy instead of u.k., got up 'change home location' on the screen and selected street and house number, tapped...
age has nothing to do with new technology,
if the language in One XL is Italian then use google translate
TomTom One XL manual page 33
Tap Change preferences in the Main Menu.
(When you first start using your TomTom ONE XL, not all the buttons will be shown in the menu. Many buttons and some more advanced features are hidden because you will not need these features very often.To see all of the buttons and features, tap "Show ALL menu options" button in the Preference menu.)
then
TomTom One XL manual page 36
Tap "Change language" button to change the language
You can choose from a wide range of languages. When you change the language, you are also given the opportunity to change the voice.
if your one is not One XL any TomTom manual can find here
Hope this help
20/Apr/09
Apr 09, 2009 | Tomtom ONE 3RD EDITION GPS Receiver
TOM TOM is frozen
To reset your ONE XL, use a straightened paper clip, or something similar, to
push the reset button. The reset button is next to the memory card slot, on the
bottom of your ONE XL. Then turn your ONE XL on.
If this helps you plz rate this. Thank you kindly.
Feb 21, 2009 | Tomtom One XL GPS Receiver
V9 Bluetooth activation
My suggestion:
First take your BT device (Not the phone), and hold down the pwr button until the light stays on constant (this is "find me" mode for most BT devices like headsets).
Next on your V9 goto your Settings/Connections & select Bluetooth, then scroll righ (or select options) to search for your device.
Once your device shows up in the screen selct it by hitting the center of the nav key and it will ask for a passkey wich is normaly "0000".
You should then be paired.
Mar 15, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Tomtom ONE XL GB Car GPS Receiver Logo
400 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
