Question about Garden
Mower starts then turns right off - Garden
Craftsman riding mower back wheels not rolling, seem locked up, engine won't start. Clutch and levers still move freely. Was running fine last use. Not sure what is causing this
Grass always gets caught in mowers. THis may help.
Turn mower off, detach battery.
Turn mower on side.
Clean grass everywhere you can clean grass.
Right side mower.
Attach battery.
Start.
Does that help?
Jun 28, 2017 | Craftsman Garden
Model 911194 starting problems.
might be battery check to make sure cutters are not engauged and your start procedure is right
Feb 23, 2013 | Ariens Garden
Start mower with key-cant turn mower off
Your throttle cable need adjusting. Your owner's manual should tell how.
Mar 11, 2012 | Garden
Mower is making a clunking noise when attempting to start and once running. blades seem quite loose.
I think that noise is because your blades are loose. They should be tightened right away because they could come off when you are using it with the possibility of injury to somebody. I have serviced some mowers with that problem. They make more noise when starting because they are turning slow and moving around more than when turning at high speed. Best regards and good luck.
Jan 02, 2011 | Garden
Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Jan 28, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
May 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
