Question about Garden
When hot will not start after cools off or when cold starts fine 18.5 hp IC brigs
  • 437 Answers
Sounds like the ignition module is breaking down when it gets hot.
This will need to be replaced. The ignition module can be expensive but cheaper than replacing the mower.
Posted on Sep 24, 2009
Toro won't start when hot
Brigs and S motor , check hot valve clearance as the valve stems stretch and then a valve is held partially open until it cools down
should be .010"inlet hot and .012" exhaust hot
Apr 28, 2018 | Toro Garden
Suzuki 650 will not start when hot
Have you checked the CDI unit. These can breakdown when hot.
May 06, 2014 | Suzuki LS 650 Savage Motorcycles
Craftsman 22hp lawn tractor when its hot i loose half the power and backfires on cold months it run fine ...brigs and stratton engine
not a expert just trying to help,, sounds like you have heat problem with the carb or the fuel line,,make sure all the heat sheids are there,, if not repllace them,,cause it will cause the gas to try to vapor lock. hope this help you
Feb 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
WONT START WHEN HOT STARTES FINE WHEN COLD WHEN
sounds like you head gasket problem or maybe cooling system needs to be bleed.
Jun 19, 2009 | 1995 Honda VFR 400 R NC30
Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Help...
If you were experiencing a failure just after a heating cycle but not on a cold start, I would suspect an electrical component failure. As the component cools, it makes contact and allows the furnace to operate. This will change and not for the better. Depending on what your system has for electrical components, I suspect either a relay or transformer. At any rate, get a technician in front of it so he/she can diagnosis it under both cold start and hot start conditions. It will help if you turn off your system so it will be cool when the tech gets there.
Nov 25, 2007 | Heating & Cooling
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
