Question about Dryers
GE DDC0580VALWH Dryer does not get as hot as it did -
GE DDC0580VALWH does not get as hot as it did - longer drying time.
The air from the exhaust still feels warm, so it's heating a little.
I'm not too familiar with dryers, but I tear anything apart to figure out how it works. (my next step!?)
  • sauder61 Sep 24, 2009
    No, I already checked that.
    I've been reading. There are 2 heating elements. Maybe it's one of them. Would that cause a problem like I'm having?
    Looks like I have to take the cover off and the drum out to access them.
  • 64 Answers
Check the exhaust hose and/flue for build up or blockage
Posted on Sep 24, 2009
Dryer is not getting as hot taking longer to dry clothes.FRIGIDAIRE MODEL GLER341AS2.
If your dryer is STILL heating, but your dryer is showing signs of heavy condensation or longer dry times, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. As the dryer exhausts, moisture from your clothing is circulated with the warm air. If you have any restrictions in the exhaust system, the moisture will collect inside the ducting and drum. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards.
If you do determine you have an internal component problem, the next link can give you some helpful advice on how to troubleshoot a dryer with a no heat problem: http://www.fixya.com/support/r3574266-thorough_dryer_advice http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat If you have any questions, please post back and let me know. I hope you find this information helpful.
Sep 15, 2010 | Frigidaire GLER341A Electric Dryer
My GE dryer DBXR463 electric dryer doesn't dry the clothes all the way anymore? What could be the problem? I have cleaned all of the lint and checked the venting on the back. It used to worked fine for...
Check the entire vent (exhaust ) system start the dryer and go outside to the exhaust vent ,you should feel a good amount of warm airflow.bet you will fine low airflow. You need good air circulation to help remove the moisture from the clothing warm or hot temps alone would take longer if ever to dry ..this generally happens slowly over time and the next thing you realize is that its running much longer than it use to... plus it cost more....if you still have a concern you may have a thermostat that is short cycling not letting it get hot enough long enough... Hope this helps GOOD LUCK
Aug 21, 2010 | GE DBXR463EBWW Electric Dryer
Dryer takes two(2) cycles to dry
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
Jun 22, 2010 | GE DPSR610EGWT Electric Dryer
Dryer doesnt get hot anymore after 2 yrs
You may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you don't have any clogs. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
If you have any questions, please post back an let me know. I hope you find this information helpful.
Apr 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The dryer does slightly heat up but not enough to dry the clothes. There is luke warm air coming out of the vent. On high heat it takes over an hour to dry the clothes and they are not all the way dry.
You may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
Apr 28, 2010 | GE DBLR333EE Electric Dryer
My ge dryer takes 5hrs to dry a load of clothes, it seems hot enough inside when i open it but the clothes used to dry in 90mins or so now its hours
Have you checked your lint filter? Do you empty your lint filter after every load? If it is hot inside the dryer then the most likely suspect is a clogged exhaust vent. Check the lint filter, if it is clean pull the dryer out from the wall and disconnect the exhaust hose. You may have to clear out the exhaust hose...compressed air usually does the trick. After you have done this, put everything back together and your problem should be gone.
Sep 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Towels won't get dry in GE dryer
there is a blower wheel that move the moist heat air out,i think you have a clogg on the dryer vent side or the wall vent side,they need to be cleared or the dryer holds the moist hot air in the dryer and takes forever to dry,let me know how you do--mike
Nov 12, 2008 | GE Dryers
Bad heat in two year old GE DBXR463ED2WW electric dyer. Not as hot as used to be, takes longer to dry!
If you're experiencing a dryer that requires a longer time to dry, you may want to view this link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the first major paragraph. I know the link is for a no heat problem, however, if you have a dryer that is starved for air, the heating circuits will eventually fail. In most cases, a no heat, or longer dry time problem is directly associated to clogged ventilation, kinked dryer vent hoses, improperly installed vent ducting, a clogged blower fan assembly, or rodents. Yes...the last one isn't always fun, but I have found bird nests, mice nests and even snakes inside dryer vents, clogging the air flow. The symptims were all the same - a dryer that would not dry properly. Before you assume you have a component going bad, take a good look at the way your dyrer is installed and inspect it thoroughly for what might be a good cleaning. The outsiode dryer vent should be at least 12 inches off the ground and a louver is recommended to cover the end to prevent critters from getting inside. In addtion, the SHORTER nd STRAIGHTER the dryer exhaust vent is, the better. If you have an exhaust vent with excessive bends, or excessive run length, this can contribute to poor heating of the dryer. Especially exhaust vents that run thorugh an attic or under a crawl space. They typcially develop sags, which create choke points where lint can accumulate to the point where it clogs. I do not know what your situation may be, but provide this as some helpful guidance just in case. I hope you find this information helpful. If you inspect your dyer and still have problems, please post back and let me know.
Sep 03, 2008 | GE Dryers
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
Drying time is longer than usual.
Check if you have a reasonable amount of airflow when it is operating. You may have a broken connection in the joint or a problem with the dryer fan,
May 17, 2017 | GE Dryers
Dryers Logo
239 people viewed this question
Top Dryers Experts
