Question about Garden
HI I have a Craftsman lawn tractor model 917.274641 purchased in 3/05. This model has an automatic transmission. My problem is as follows: I was mowing the lawn.......stopped the tractor and turned it off to do something else. When I returned tractor would not start. I was able to jump the battery with my car (instructions say you can do this). I continued to mow for 10 minutes when the engine shut off suddenly in the middle of the cut. I have replaced the battery.....now I can't even jump start it. When I turn the key, there is only a clicking sound and then a low level squealing sound. My mechanically inclined neighbor has attempted to help me diagnose the problem. Thus far we have checked the fuse under the instrument panel with a vol-con tester.......it is ok. While I was in the seat, he tested the solenoid connection (he put a crescent wrench between the two poles and got a spark as I turned the key to start. Still no start. This is where we ended up. Any assistance to help diagnose this problem would be appreciated. Lew
  • 1 more comment
  • ljwaltersjr Sep 30, 2009
    Thanks eliase,
    I took the blower housing off of the tractor to gain access to the engine......I was able to turn the engine and saw that the starter gear pinion was engaged with the flywheel. I disengaged the gear pinion from the flywheel and sprayed it with WD40. When I tried starting the engine.....the gear pinion popped up to engage the flywheel.....with a cranking sound as though the engine was going to start, but then stopped. When I turned the key again, I only got a clicking sound. I think the starter is bad and am going to replace it. What do you think?
    thanks
  • ljwaltersjr Oct 01, 2009
    I installed a new starter. Now, the engine turns but doesn't start. As long as I hold the key to the on position it turns, but don't want to run the battery down. I'm at a loss now.
    thanks, I have checked the gas level...ok and choke is on. Haven't tested the ignition system yet, but In the meantime since my last post, I tried to remove the spark plug to take a look. I couldn't get it to budge......a neighbor tried too......so sprayed it with WD40 to see if it would loosen up. It loosened up but was very hard to remove. The electrode end (part going into the head) of the plug was SMASHED....the electode (not sure what you call it) that curves out was missing and the center one was bent to the side........part of the threads at the tip were gone. I looked in the block and the threads are stripped. I think it might be a blown valve?????? Reiterating what happened when the tractor originally shut down.........the tractor just stopped.....with sort of a reved sound (I was wearing ear protection.....so couldn't hear it clearly.
  • 299 Answers
Try turning the engine by hand if it doesnt turn the engine is bad
Posted on Sep 24, 2009
Testimonial: "thanks so much for your assistance. In the end, had a mechanic put a cam in the spark plug hole into the engine......the rod came loose from the cam"
  • 1 more comment
  • Eliezer Miller Sep 30, 2009
    sound like it may be a bad starter good luck
  • Eliezer Miller Oct 01, 2009
    make sure you have enough gas also make sure that when you replaced the starter you didn't mess up the ignition system the way to check this is to go to autozone or a similar store and get a spark checker hook it up and see if you have a spark if not check your starter installation also make sure the choke is on when you try to start it
  • Eliezer Miller Oct 02, 2009
    now that the plug is out look in to the bore while an assistant engages the starter(using eye protection) if the piston is still moving back and forth try replacing the spark plug but i suspect it wont be no this is not likely a bad valve since that would contact the piston and destroy that not the spark plug and the noise from that would be extreme if the engine is gone consider replacing it its only a 3.5 hour job according to the manual
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Automatic transmission does not work
Is the little wire looking lever pushed in at the rear of the tractor.
Is the belt tight and on the pulleys.
Nov 11, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Craftsman lawn tractor, model # 917.276180. After mowing for about an hour, the transmission starts to slow down and eventually stops. The tractor s/n is 03006D006025 and was purchased new from...
Hi, remove the battery and battery carrier and clean all grass and debris from the hydrostatic drive, cooling fins and fan. I'm not sure what transmission it runs but the solution applies to all. Hope this helps, regards Phil.
Aug 25, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have Craftsman 42" lawn tractor with the automatic transmission. It runs fine but it is not pulling a grade now. The belt seems tight, what could be the problem?
As you attempt the incline grab the clutch pedal with your heel and pull it towards you if it starts pulling correctly you have a belt problem . If it makes no difference you are having hydro pump problems
Jul 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a 19.5 HP Craftsman lawn tractor ,automatic-it will run forward but slower than usual and in reverse very, very slow. does it have a place to check the transmission fluid? It has recently had a new...
Personally my best advice is to take it back to the tech. Why? Because they should stand behind it if they just installed it and two...it may void the warranty if you touch it
May 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
  1. Lift the tractor / mower seat (pull it up)
  2. You will see there's a small metal label with the serial and model number of the tractor / mower
  3. Check the serial number of the tractor / mower
  4. the first six digits of the number are you the model month day and year (i.e 090999XXXXXXX this tractor was made in September nine in 1999
Hope this helps
Attached is an image of the tractor seat and the metal plate
Sep 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Apr 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Mar 30, 2009 | Craftsman Garden
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
