Question about Lexmark X5470 All-In-One InkJet Printer
Will not feed paper in the top of printer to copy or fax multiple things
One day there was a pop and not it will not feed how can i repair this because to fax I have to scan one page at a time
  • jismann Dec 16, 2007
    When i put the paper in the auto feeder, it does not feed the paper to the scanner!!!
  • Anonymous Mar 05, 2008
    Scanner will scan from glass but not through paper feeder on top of machine. How can I fix this problem?
    Champion:
  • 238 Answers
Please be specific, ur question is not clear,, bye..
Posted on Dec 16, 2007
During multiple feeds, the 1st copy is okay, but on the next succeding copies, top margins spacing varies that will cause the bottom copies to be cut
Meikriezl Ulit:
Remove the paper tray and use a "Q-Tip" dipped in alcohol to clean the paper pickup roller and the double-feed prevention pad (below the paper pickup roller.
Feb 24, 2013 | Toshiba Office Equipment & Supplies
Hi, the printer is saying paper jam when there isn't one. it won't scan or copy from the glass and will copy from the paper feed but only 1 copy and then comes up paper jam again. if you turn the...
there are many spring loaded switches within a printer that monitor the location of a sheet of paper, it is possible that one of these switches got stuck and is the cause of your problem. Printers can be quite difficult to work on, so I would recommend taking it to a local repair shop to have it looked at. If the switch is simply stuck it may be a quick and easy repair.
Another thing to look at is to make sure all of the rollers that feed the paper through your printer are moving, if one is stuck it could be giving you the same error.
May 05, 2011 | Office Equipment & Supplies
How can I print from the top of my brother printer
Hi
You cannot print from the top feed,
The use of the top paper feeder is the capability to make single or multiple photocopies and for single scanning or multiple scanning. All you have to do is to put single or multiple document in the top feeder and press the COPY BUTTON (third button-right side). Then it will feeds automatically.
The same with scanning, press the SCAN BUTTON (first button-left side) and it will scan single or multiple document.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 10, 2011 | Brother MFC-8460N Laser Printer
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
Sheet feed won't work
When you reinstall the blue plastic piece underneath, the white plastic sheet that closes over the glass must hang over the blue plastic piece, not tuck under it.
Mar 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper feed jams
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Photosmart C7280 Laser Printer
Paper feed
in the printer dialogue that pops up prior to printing choose the number of copies
Oct 14, 2008 | Canon Pixma iP6600D InkJet Photo Printer
MFC 440CN fax machine
Is this through the ADF (top feeder) or from the paper tray? Either one can have some build-up on the paper feed rollers and would have to be cleaned.
Jan 08, 2008 | Brother MultiFunction Center MFC-440CN...
Paper crinkles for fax or copies
either your feed rollers are bad or there is a piece of paper stuck
Dec 05, 2007 | HP LaserJet 3030 All-In-One Printer
Lexmark X5470 All-In-One InkJet Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
