Question about Gateway CX200S Tablet PC
How do i load pictures from a sd card into computer
    Problem Solver:
  • 12 Answers
Determine if your computer has a memory card slot for sd cards..
if memory card slot is not available use a "card reader" you can get that from walmart and on other stores
once memory card is connected.. it will appear on your
computer as a removable disk or device.. you can check that on "my computer" window for XP or "computer" window for vista..
you can explore the content of the memory card and get your files.. good luck!!
Posted on Sep 24, 2009
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Jul 10, 2016 | Tablets & eReaders
How to get my pictures and videos off my Android phones SD CARD to my nextbook flexx10 by putting the SD card into the laptop
The Flexx10 has a micro SD slot, the SD card is about the size of your finger nail. If your Android phone also has a micro SD card you just remove it from the phone and plug it into the Flexx10. Then just transfer the pictures from the SD card to the tablets internal hard drive. When complete put the SD card back in the phone. If the SD card in your phone is the standard size it obviously won't fit the Flexx10. You then have the choice of either using Bluetooth to transfer the pictures between devices or buying a USB SD Card converter and plugging that in your FLexx10 with the Android SD card mounted in the converter.
Feb 06, 2016 | Nextbook Tablets & eReaders
I put an SD card in to get more storage and I don't know if it is acknowledging the card because when I want to download it still tells me that I don't have sufficient storage.
Unfortunately, the SD card in most tablets and cell phones doesn't get used efficiently. Most apps will not load onto the SD cards since the developers don't write the programs to run from them. Thus, you are limited to what's in the tablet or phone natively. The only thing the SD card does mostly is to allow you to store more pictures and video files. Some apps will put their data there, but you must direct them to do so in the app management menu. Until manufacturers put more memory in the devices or programmers write the apps for the SD card, that's the way things will remain.
Feb 05, 2016 | Samsung 7 Galaxy Tab 4 8GB White
Says my sd card is unmounted or no files are on it. what happened to my files?
When you remove an SD card from its slot, you should *unmount* it first so you don't lose data. If you just pull it
out without first unmounting it, you could corrupt it and lose
data. This might have happened in your case or not. If you didn't remove it, try this.
Go to Settings>Storage>External SD, touch Unmount.
Then remove your SD card and using a Q-Tip and some
solvent like alcohol clean the copper contacts. Then slide it
back into the slot. The device should *Mount* it automatically.
If it still doesn't work, you could try hooking your device up to a computer via its USB cable and see if your computer can see any files on it. If it can't see any then somehow they could have gotten erased. Try loading them back. If they won't load and you get error messages, the SD card itself may have gone Kaput.
Apr 17, 2015 | PANDIGITAL Tablets & eReaders
Photos on verizon tablet were not stored on sd card, how do I get them on sd card
According to Verizon support:
"From the Device to a Removable SD Card This feature is not available on the Verizon Ellipsis 7 Tablet"
However, you can transfer photos from the tablet to a computer; and then you can transfer them to a removable SD card if you have an external USB SD card port reader or one that's PC integrated.
According to Verizon customer support:
From the Device to a Computer
  1. Connect the device to a computer using the supplied USB cable.
    1. If necessary, select and hold the status bar (at the top) then drag to the bottom.
    2. Select Connected as a camera / an installer.
    3. Select Media device (MTP).
  2. Launch Windows Explorer.
    linote.gif Using the computer keyboard, press Windows+E ( windows_key_logo.jpg+E) keys.
    linote.gif Alternatively, right-click Start then click Open Windows Explore.
  3. Using Windows Explorer, navigate: QMV7A.
    linote.gif If you have a microSD card, you may transfer files to that location by navigating: QMV7A > SD Card.
  4. Utilize the computer to copy video/picture files from the following folders to the preferred folder(s) on the computer:
    • DCIM/Camera
  5. Disconnect the USB cable from the computer.
Feb 28, 2015 | Verizon Ellipsis 7 Tablet for Wireless
How do I load APS to SD card, my Simban 100 will not load anything beyond 8gb internal memory.
one way that always works though a few steps.
get an sim adapter for the sd card for your computer they are cheap to buy.
connect cable to your simban 100 an copy what you want off of it too.
now put all you want on the sim connected to your computer with sim adapter.
when finished you now have any apps you want on the card. generally.
if you want to load apps from the sim you have to go to security setting in tablet n set it to allow that.
Jan 05, 2015 | Tablets & eReaders
How do u access sd card to down load photos - galleries/M729B?
Insert in slot marked for SD... go to my computer if it's windows machine... select drives... look for drive that has d or e next to it... double click and see if your pictures are there...if so right click on the pic you wand and select save to... and pick a spot on your computer you want em...ie picture... photo album...
Dec 02, 2014 | Tablets & eReaders
Instructions manuals
pictures should already be loaded to SD card... if not, you probably need to format SD card and then try again. I've had issues with SD cards going from laptop to Tab 3 but my pics taken with my camera always load to SD card. Now pictures I have downloaded from the internet I can open up in my Gallery, tap the picture and then hit settings and move to SD card
Dec 19, 2013 | Samsung Galaxy Tab 2
Gateway CX200S Tablet PC Logo
442 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
