Question about Sebo Automatic X1 Bagged Upright Vacuum
Sebo x1.1 fitted with new bag and filter but red bag check light still comes on and then machine shuts off. Any ideas how to remedy?
    President:
  • 389 Answers
Without doubt this indicates that there's a blockage somewhere. The two easiest places to look are: 1. on the underside of the machine there's an inspection flap - check in there; 2. remove the flexible hose completely from the machine at both ends - check in the hose itself, and where it enters the machine near the handle .  The only other place to look is where the base connects to the bag compartment - to check there, you need to separate those two parts by pressing the button at bottom front of bag compartment and pulling the base away (this can be difficult - four hands would be useful - but once you're pressing that button, nothing else other than friction is holding the parts together). Once the parts are separated, check every orifice you can see (the parts just push back together again).
I think that covers it.  Good luck, and please remember to rate this response.
Posted on Sep 26, 2009
Tip
Useful Tips for Sebo's X1 Bagged upright vacuum.
Own a Sebo Automatic X1 Bagged upright or perhaps a Windsor-Sensor model? Here are a few tips to get more out of your machine.
When it comes to filter replacement, the standard cone/tube shaped filter can actually be cleaned by the Sebo if only just for a short moment just to get rid of any attached dirt the filter has accumulated. By removing the filter tube, the auto stop clip comes down, but by lifting your finger with this clip upwards and your other hand holding the bin door, the door can actually be locked back into position as it would normally. Then using the standard upholstery t shaped tool, clean the tube leaving it free of any dust and dirt contained in the tube. Once the tube has been cleaned you can take out the bin door and install the filter back in. Sadly the foam motor filter on the top hood cannot be cleaned or washed and has to be replaced.
If the filter tube however is completely stained and you dont have a free spare one to fit, the filter can actually be removed by removing the tie clips on the top and bottom of the holder. Wash the filter and dry in a tumble dryer - EBay in the UK sometimes sell filter squares which can be tied and locked to the cylindrical tube. Once the filter is dry you can then tie it up to the grid again and if the ties get lost, small computer wire ties are a suitable replacement.
Another feature of the Sebo X which has only just come to light recently with Sebo's user videos is use of the dry cleaning powder. Although Sebo don't actually tell you, by manually rubbing the powder into your carpet with just your fingers rather than raking it in on the top surface you'll get more out the first application of rubbing the powder in and letting it get a better chance of removing actual heavy stains. If you don't want to rub that powder in manually, remove the top hose by unlocking it where it meets the bag dirt channel on the left hand side of the machine at the top. (right hand obviously if you are facing the Sebo) then the Sebo X can be used as a rolling  brush to rub the powder in. After the 30 minutes minimum waiting time, lock the hose back into the X and vacuum up as normal.
This facility of removing the hose/thus cutting the suction is also very useful to rub in bicarbonate of soda into your carpets if you own pets. Bicarbonate of soda is an ideal natural odourizer which will maintain clean areas. Sebo's DuoP dry powder is ideal to do this as well for general stain protection if you like to keep your carpets clean.
The paper bags can also last a lot longer if the dirt your Sebo has collected remains half way at the top rather than naturally falling to the bottom of the bag.My X1 does this with new carpet fluff. Take the crevice tool and push the tool into the top opening of the bag to push the dirt GENTLY down - this will give you extra longevity on the bag used as well as not having to replace it so often.
There are ways to make your Sebo X1 cost effective!
on Mar 28, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
What is the right bag for sebo x4
  1. First, pull out the hose, turn the unit on, check for an obstruction in the hose. (unclog and obstruction)
  2. Separate the body from power nozzle. Check for obstruction in the air hole passage.
  3. Pull and clean both filters in the unit. The inside white long carriage and the exhaust filter located above indicator panel. (nozzle body)
  4. If this is not working. think about where and how dirt is carried or passes from the front floor nozzle or through the hose.Somewhere in the unit the it is clogged. The red light censers a full bag (we know that's not the issue) or an obstruction to the normal air flow.
  5. Last Resort contact http://www.sebo.us/contact_us.aspx
  6. In closing: I've been selling and repairing vacuums for over 30 years. Of all the 5 major brands that I sell. Sebo is by far the, best product on the market.
Aug 23, 2014 | Sebo X4 Bagged Upright Vacuum
Bag full or clog light comes on but new bag and no blockage... Sebo x4 upright cleaner
Have you checked the filters to see if they are blocked and need cleaning/replacing. Failing that it could be the sensor at fault.
Jul 25, 2010 | Sebo X4 Bagged Upright Vacuum
New Filters have been fitted on the Sebo automatic XI
OK - I'm a Sebo expert, and we will get to the bottom of this! I need you to do one thing for me: lie the machine on one side, then switch it on and look to see if the brush roller is revolving - KEEP FINGERS and all loose items WELL CLEAR. Does the brush revolve? Then, with the machine switched off and unplugged, see if you can rotate the brush roll by hand. Does it revolve easily, or is there a lot of resistance? Then post a reply here saying what you observe. I'll get back to you when I've got your reply.
Feb 24, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
The red light on the cleaner keeps coming on. I
It could be clogged or there is a sensor adjustment for this machine and it takes a very small screw driver to adjust it. Take it to a certifies Sebo dealer and he can fix it in just a minute.
Nov 26, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Full bag clog light
1.If your sebo is less than five years old, you have a reciept, and are not using it commercially, in most cases this machine will still be under factory warranty. To locate
an authorized sebo dealer simply call sebo or use the dealer locator on their website.
2. If it is no longer under warranty:
First i would pick up something small such as a balled up gum wrapper and make sure it makes it to the bag, more often than not something is not checked, and its still plugged. Heres how i'd check for plugs.
  • Pull the wand out and remove it from the hose by pressing the button on the wand look through the wand
  • Remove the hose from the machine by pinching the hose clamp and pulling the hose out (it simply presses back in when you are done)
  • press on the large button below the bag compartment on the front. (its often a different color and presses difficultly) lift the bag compartment and handle off the powerhead. (replace by simply pressing the bag compartment back onto the head)
  • look down the powerhead and inspect the other areas of the bag compartment.
  • open the orange/gray door on the bottom of the powerhead and look through checking for debris.
Simply go back up through the steps to reassemble.
If your test makes it into the bag just fine and you are not plugged, the tall filter inside the bag compartment would be my next suggestion and since you changed this it should not be a problem. This leaves few possible problems. Circut board error/Sensor error would be my next step. Essentally its one in the same, but there is no great way to test them without simply replacing parts. (an expensive proposition) The local sebo dealer will more than likely have a working used board they pop in and out to check for problems. Some dealers may let you use these others will require you either buy the parts or pay for labor.
*Bad boards in sebo/windsor products are extremely rare, my bet is always on a plugged filter or plug in general. Be sure to look carefully something as small as a toothpick surrounded by carpet fuzz can set them off.
Best of Luck
Jun 05, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Jun 22, 2008 | Sebo X4 Bagged Upright Vacuum
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X14 -red light comes in for clog or bag full. , bag is new. Cleaned out all clogs
Unless the circuit board is bad, you still have a clog, Either in the hose, or the dirt inlet by the brush roll.
May 05, 2008 | Sebo Vacuums
Sebo Automatic X1 Bagged Upright Vacuum Logo
157 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
