Question about Samsung SGH-T619 Cellular Phone
Cell phone will not activate the bluetooth
Each time I attempt to put my cell on bluetooth all I get is "bluetooth activate error" How can this be corrected?
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How do you send songs to another phone via bluetooth?
Hi, Please find the file (song) on your cellular phone (don't play)>> click option>>choose send>> choose bluetooth (then enter/Yes) Now your phone will activated the bluetooth and searching for active devices around you ( make sure before this step you've activated others bluetooth to be paired with your phone). Then select the active device to paired. Now the transferring data is begin. Wait until the process completed. Now you have a copy in another phone.
Sometimes you wish to send multiple data / songs in the same time. Just put the mark on each data /songs then follow above steps.
Dec 04, 2010 | Cell Phones
My genio touch bluetooth will not activate. When I tap to turn my bluetooth on it takes more than 30 seconds saying activating Bluetooth then it says ? activating bluetooth failed " please help me what do...
Hi, when a blue tooth takes time to activate,it usually caused by VIRUS on the phone.
You will need to reset the phone or flash the phone to remove the VIRUS. Flashing the phone removes VIRUS from phone.
Reset code:*2767*2878# or you can flash with the below link:
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Have a nice day.
Sep 03, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Im try to transfer files using bluetooth from a samung m8800 to a sony erricsson mini x10 its saying on the sony erricson paired but not connect both phones have active bluetooth and when i try from the...
Good day,there is probably an error in the established bluetooth link between the phones,my solution goes thus;
Put off the two phones and turn back on after 5mins,reconnect the phones via bluetooth and transfer the files,if the problem persists,it means the problem is solely from either of the phones,try transferring with other phone to establish where the fault is from and let me have a fitback to this solution
Thank you!!
Jun 23, 2010 | Sony Ericsson X10 mini Cell Phone
Bluetooth activate error
HI,
Please pair the device with the phone? if not then read the manual of the bluetooth and pair them first.Also try turning the cell off & removing the battery and then turn oin again to see if the issue is solved.
Feb 10, 2009 | Samsung SPH-M610 Cellular Phone
Bluetooth problem...
same thing happened to mine. I already bought a new battery, but it seems that the problem is not on the battery. This bluetooth error appears to be the problem for draining my battery.
Dec 22, 2007 | Samsung T809 Cellular Phone
Bluetooth error and infa
your bluetooth inside the phone does not make proper elctrial contact on the board ta it to the service provider to re install the bluetooth device. advice by dogy.
Dec 16, 2007 | Samsung SGH-D500 Cellular Phone
Bluetooth
I know that it is not very helpfull to say this,but you are not alone with this fault which appears to be quite common to the D500.I assume that the same notice appears when you attempt to activate IR as this is usually the case. The only suggestion that has been doing the rounds is as follows. Remove the back and look at the chassis and you will see a square IC unit near the battery connectors. Apply heavy but carefull pressure on this and try the Bluetooth again. This is said to have cleared the fault in at least two cases.
Dennis
Dec 04, 2007 | Samsung SGH-D500 Cellular Phone
Samsung SGH-T619 Cellular Phone Logo
98 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
