Question about Sony KP-57WS500 57" Rear Projection Television
Color is bluing (blue bleeding thru)
I have a Sony wide screen (rear projection) and blue is starting to bleed thru all the other colors. I called a repair man and he told me it was the tube. He went further and told me the tube may not be completely sealed and a dust particle may have gotten into it. He said there is a process/piece of equipment he can do at his shop to reseal the tube (take about 4-6 hours). It this true? Should I just buy a new set, or find a new repairman?
  • 157 Answers
You can remove front speaker cover,then remove screws from board,you will see 6 controls,3 are focas(all in a row)3 are screen controls.sets are for red green and blue,blue should be to the rite,turn blue controls until picture gets better.they are labeled screen and focas
Posted on Sep 24, 2009
I just replaced the bulb in my Sony 55'' Grand Wega. the picture looked fantastic the first day. turned on the TV the next day and everything that should have a ''white color'' looked pink. the blues...
Please adjust TINT control of Video Settings in Menu that will adjust color tone of TV. I do not think this problem is related with Lamp because TV screen does not have any color blobs or spots.
Above solution is for Sony KDF-55WF655 model TV, if your model number is different, let me know.
Thanks.
Nov 29, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have color bleeding or washout in solid colors? does that mean the lamp is going bad?
I am not sure which set you have, but, when colors are bleeding on a projection set that is a good indication that the tube is going bad. The color that is dominate, red, green or blue, this will tend to bleed across the screen. If I had more information on your set I could give you a better suggestion, but if it is a tube it will be a costly repair.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 25, 2009 | Mitsubishi Televison & Video
I have a Sony wide screen (rear projection) and blue is starting to bleed thru all the other colors. I called a repair man and he told me it was the tube. He went further and told me the tube may not be...
common failure of this one is convergence.when unit is on does the blue or red not sit ontop each other.go into menu find convergergence see if you can adjust the red onto green then blue onto green.if not you have bad convergence ics part number STK392-560 use STK392-570,also check pico fuses(yellow) all 5 amp location ps8006,ps8002,ps8004
Sep 24, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Colors appear to be bleeding out to the side.
have you tried the blue convergence adjustment via menu
Aug 25, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Blue dots in center screen after installation of new home theater system
Looks like you may had some unshielded speakers near the back of the unit the caused the color to bleed or fade this is perm damage to one of the guns that shoot the pic to the mirror. There is a fix for it but it may be a costly one.
Apr 22, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Fadded red "video 1'' stuck on in corner
Your getting video bleed thru the filtering circut that controls this is weak Capacitor most likely.
Dec 05, 2007 | Sony KP-53HS30 53" Rear Projection...
Bleeding blue color upon projection
Yes you can replace the lamp, but service in must including the RGB Panels for the same. that will solve ur problem.
Viren
Nov 24, 2007 | Sony VPL CS1 Multimedia Projector
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Mar 17, 2007 | Toshiba 53HX71 53" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
168 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
