Question about NEC VT460 Multimedia Projector
NEC vt460 Projector have a ghost problem on the screen
I have NEC VT460 Multimedia Projector and after changing the lamp there is a ghost problem occured. How can i solve the double image problem
  • 3 more comments
  • aspring Dec 27, 2007
    Similar or the same problem - I have a ghosting issue also. Show's also at the right hand side of the picture particularly.
  • 78xtc Apr 06, 2008
    we also have the same problem - the ghosting is a purplish colour.
  • Anonymous Mar 20, 2014
    Is it possible to connect XBox 360 to a projector NEC VT46 LCD
  • Anonymous Mar 21, 2014
    the nec projector shuts off after a few minutes of being on and working just fine
  • Anonymous Mar 30, 2014
    The projection becomes reddish, unlike what is displayed on the PC. Changing the bulb does not solve the problem.
Can you explain what the LCD panels are please.
Posted on Mar 19, 2008
  • 115 Answers
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Posted on Feb 07, 2008
Pj402d projector lamp goes out after a few seconds
Check the ballast module. It controls the lamp operation
Nov 26, 2013 | NEC VT460 Multimedia Projector
Message on screen-The bulb has reached the end of its usable life....and it has 97 hrs left and can't clear the message.
select Menu>>>[default]>>>[Clear Lamp Hour Meter]. do this after replacing the lamp.
below is a link to the manual. what you seek is on pgs E-30,31. Good Luck!
http://www.support.nec-display.com/dl_service/data/manual/english/vt660k_e.pdf
Sep 13, 2011 | NEC VT460 Multimedia Projector
Brightness of the projector is poor
it may be the fly-eye lens. it tends to fry due to excessive dust and heat. it'll need to be replaced. there are 2 of them. the first one is right inside the lamp housing. the second one is on the other side of that. the 2nd one is the one that is bad. you'll have to send it back in for repair. nec doesn't sell individual parts.
Dec 28, 2009 | NEC VT460 Multimedia Projector
My lamp light stays on my status blinks
if it's blinking red, how many times? 1 time- lamp cover. 2 times- overheating. 4- fans. 6- lamp. if the lamp led is lit red, replace the lamp.
Dec 09, 2009 | NEC VT460 Multimedia Projector
Double display
Hi yaali
Try using a different cable.
If the problem however persists , then you will have to get the Mainboard either repaired or replaced.
May 17, 2008 | NEC VT460 Multimedia Projector
NEC VT 460 LCD Panels & Fly Eye Lens
HI there
Firstly this ghosting image will NEVER be caused by your LCD's , so do not take them out.
Have you tried using a different cable ?
If you have and the problem still occurs , you will have to look at replacing the Mainboard.
Apr 13, 2008 | NEC VT460 Multimedia Projector
Blub brightness has dimmed.
Replace the Lamp unit is the best solution. that will cost you around $450.
Viren
Sep 08, 2006 | NEC VT460 Multimedia Projector
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
NEC VT460 Multimedia Projector Logo
1,495 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
