Question about Sony Handycam DCR-TRV140E Digital Camcorder
I have a Sony DCR-TRV30 and it just gave me a self diagnosing error C:31:23 and I can not clear it even taking out battery and tape and reinserting it does not clear can you tell me what else I can try
  • Sony Master
  • 586 Answers
Error C:31:23 is related to mechanically misalignment of the tape loading path, and it removes when mechanical adjustment performs, a sensor in mechanical section detects mechanical problem and generates the error. This error removes automatically when the problem solve. For mechanical adjustment contact any expert nearby to perform the adjustment.Which is bit technical and can only perform by an expert.
Thanks for using fixya.
Posted on Nov 01, 2009
My Sony TRV30 MiniDV camcorder always gives me an error when I insert a tape. It won't playback nor will it record, it just says to eject the tape, like it did not load correctly. I try repeatedly, but it...
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 24, 2010 | Sony Handycam DCR-TRV30 Mini DV Digital...
DCR-TRV30 Internal clock battery is end of life. It will not charge overnight or hold date/time set information between main battery changes. There is no replacement information in the user manual. Where...
This small back-up battery on my Sony is under the main big power battery, it is like a large screw under the main power pack, I just turn that screw and the little round lid comes off to get to the little silver flat back-up one.
They are readily available from most good camera shops like Jesops for around £12 to £15 each.
May 23, 2010 | Sony Handycam DCR-TRV30 Mini DV Digital...
Camera flashing error E:91-01 on movie camera model DCR-TRV30
This worked for me: With camera power on, push RESET (located left of the rec button in the main panel).
Apr 02, 2009 | Sony Handycam DCR-TRV30 Mini DV Digital...
Video recording shuts down after 15 seconds
I just looked at my Sony DCR-TRV30. Not the same, but perhaps similar. My camera records lengthy videos on tape and only brief videos on memory stick. I suggest that you stick to tape for video.
Good Luck
almarc13
Feb 12, 2009 | Sony Handycam DCR-TRV730 Digital Camcorder
I need the DCR-TRV30 driver
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV30
go here and click driver download
Dec 17, 2008 | Sony Handycam DCR-TRV30 Mini DV Digital...
Sony DCR-TRV30 Error Code 31:23
First, you have to disassemble the camcorder to get to the mechanism. Then once you get the mechanism separated from the rest of the unit, the cassette basket or tape loading mech has to be removed. Once you remove that, there is a dress panel with the tape sense LED attached that will have to be reomoved. Behind the dress panel is a swing gear that drives the reels. The swing gear depends on friction from a clutch behind the gear (but it's part of the gear). the reason it stops working is that the clutch wears out so the gear won't swing and engage the reels (Sony calls it a "gooseneck gear" p/n X-3950-364-1) Replace the gooseneck gear and that SHOULD take care of your problem. Also check to make sure the reelshaven't been bent, this sometimes happens if you "misload" a tape. Be sure to rate this solution. Thanks!
Nov 08, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony Handycam E:40:00 Error Help
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 12, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
Camcoder not starting up
Feb 11, 2008 | Sony Handycam DCR-SR42 Camcorder
Sony Handycam Vision ccd-trv308
Jan 22, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony Handycam DCR-TRV140E Digital Camcorder Logo
211 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
