Question about Water Heaters
I have hot water but no heating pumb working ok
    Champion:
  • 248 Answers
Check pump
Posted on Oct 12, 2009
What will happen if I accidentally reverse the hot and cold pipes going into my electric hot water heater during installation?
You should be OK as long as you caught the mistake BEFORE the heating elements heated up. Water will flow from either side so you should be OK as long as you had water in the tank before turning on for any length of time.
Jul 27, 2015 | Water Water Heaters
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
Aug 17, 2014 | Water Heaters
Water not getting hot in electric mode...heating element has been replaced, did not solve the problem.
Check switch and timer working ok also pencil Thermostat in side heating elemnt is ok and is turned up enough to call 4 heat
Sep 16, 2013 | Suburban Gas and Electric Water Heater, 12...
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
I have a Marey LPG tankless heater. The water temperature fluctuates. At my kitchen sink - warm water. In my bathroom shower lukewarm water. At my outdoor shower - nice hot water. How may I fix this...
Ok i intall tankless water heaters and sell them and repair them . The trouble your are hving is more than likely ,the mixing valve on your shower has a ajustment on it to prevent you from burning your self . that is the number one reason in showers when water never get to temp . What it is doing is addng cold water to your shower for you bummer . Take handle off and adjust water temp to your hottest setting . Some times you have to remove the low flow washer in shower head to get the right flow . also every time you start up your hot water it shouldbe set all the way ot other wise withe the battery 2 D models the unit will not sence flow and shut off the unit ,with some units it is a fine balancing act to get them adjusted right. If your buying a tankless water heater always buy a blower type unit that has a computer that runs it . You will be happy . If the Battery operated unit is for a cottage or a smallcabin then your just going to have to fix the pumbing to make it work right many of the safety features of the newer showers are not made to work well with tankless water heaters .
Apr 16, 2011 | RTO Lp Gas Tankless Water Heater By Marey
This on demand hot water heater works ok but it sends a gallon of cold water through it before the hot water starts. Is there a way to tweak it so it starts heating the water right away?
feel the pipes coming from the water while you turn the hot water on. It does come out hot, but it has to push the cold water through the lines first (the water that has been sitting in the pipe)
Dec 05, 2009 | Bosch Water Heaters AquaStar 250SXO...
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Water Heaters Logo
90 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
