Question about Garden
Wheels won't turn on self propelled mode. Mower runs fine but when the self propelled belt turns, the wheel remain stationary.
  • 299 Answers
Remove the cover and check the belt
Posted on Sep 24, 2009
I have a Craftsman front wheel self propelled mower. The front wheels no longer turn either in self-propel or in manual push mode. What can be done to fix this?
Take a good look at the wheel assembly. Is it rusted on from being left exposed to the elements? Remove the cover for the self propelled mechanism. Is the drive belt intact? Try turning the small pulley.
Aug 20, 2016 | Craftsman Garden
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
Lawn boy self propelled mower won't move backwards
is it belt driven can you pull it back when it not running
Apr 11, 2013 | Garden
Drive wheels won't freewheel when pulling mower backwards,
pull off what looks like hub caps and check the wheel clutches
Apr 02, 2012 | Garden
My lawn mower starts and cuts fine, but it will no longer self propel even though the wheels actually turn when I lift the rear wheels off the ground.
Have you checked the belt? There is a belt that runs from the shaft to the transmission that gets worn and streched out. It will spin the tires, but not under a load. I'm sure thats the problem! The cover is usually located under the deck.
Sep 09, 2011 | Troy Bilt 5.5hp Self Propelled Mower
My lawn mower cranks fine and runs fine, however, the wheels will not self-propel, anymore. I'm not sure how old the mower is, as I purchased it used, but it worked properly for the first four or five...
First of all clean all the gunk from all the drive wheel areas and where the drive belt operates as well as the pulleys Check the belt as it could be broken or stretched. Maybe should replace the belt and lubricate all the working areas as well as wheels. Check the shear pin as well.
Sep 21, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Can't push my self propelled lawn mower!
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Sep 11, 2009 | Poulan Pro " Pro" Self Propelled Mower
Garden Logo
512 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
