Question about Microsoft Windows Vista Ultimate Edition
Oxygen 8 keyboard won't work with vista - Microsoft Windows Vista Ultimate Edition
Gateway keyboard
I used to work a Tech Helpdesk, but I need more information. Is your mouse working? Is your keyboard registering with your computer? What operating system are you using (Windows XP/Vista/7/8)? You may have to go into the BIOS, but hopefully not. Is it just the screen that is "locked"? If you can provide any additional information, I may be able to help you.
May 01, 2013 | Computers & Internet
Weird midi
A few things to try:
1) if your oxygen is connected using a midi cable instead of a usb cable it could be that the midi cable is damaged.
2) you may want to try changing the preset of your oxygen: use the buttons on the oxygen, near the two digits led, to selelct a program between 01 and 15, this will change the values assigned to the knobs
3) you may have some kind of midi loop going on, try going to the preferences in ableton and disable all midi controllers (remote, sync, track) both in and out; then enable only the oxygen for track IN and remote IN which is actually all that you need.
Jan 16, 2013 | M-Audio OXYGEN 8 USB Controller
My vista home key won't work
Double check to make sure you entered the code correctly. Zeros look like O's and vise versa. Also, B's look like 8's....
Sep 04, 2012 | Computers & Internet
My m-audio oxygen 8 got wet. is it destroyed?
no not completely if you take it to an electronic store they usually can fix it
Dec 29, 2011 | M-Audio Oxygen 8 V2 Midi Keyboard
Hi i can't get my m-audio oxygen 8 minni key bord to make sound when i plug it in to my proo tools 8 m-powered essential can you please explain to me how it works
Oxygen 8 is a MIDI keyboard only.It does not produce any sound of it's own.
It opperates with instrument software that either plays as a standalone(a self contained program)or as a virtual instrument(VST,DXi)in a Digital Audio Workstaion(DAW).Sonar,Cubase,and Ableton are examples of DAWs.
Jul 10, 2011 | M-Audio OXYGEN 8 USB Controller
Oxygen 8 Recognized but not working in OSX
i read somewhere, and it worked for me, at least in logic, that when i plugged it into a usb powered hub, it showed up in the audio/midi setup as a keystation and logic accepted its input..... when i had it plugged into the cpu direct (w/o hub) it was useless.... hope this helps....
Dec 18, 2008 | M-Audio OXYGEN 8 USB Controller
Oxygen8 v2
Well do u have the controller CD? Because I bought the MIDI board as well yesterday and found out that w/o that CD installed it won't work. But my problem is the CD won't install on my vista because its not "compatible" any ideas?
May 24, 2008 | M-Audio OXYGEN 8 USB Controller
Microsoft Windows Vista Ultimate Edition Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
