Question about Motorola Mobility RAZR V3x Cellular Phone
Exactly the same problem
Had tried a master reset & master clear, but the telstra splash screen for both startup & power off still display. Have tried a firmware upgrade but the same thing. The only thing could do was remove the animated telstra gif's and pictures from the phone, but now it just displays a blank screen with only the sound
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Motorola factory reset
Apps > Settings > Backup & reset . Factory data reset
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
For older phones: Master Reset or Master Clear
Mark
Motorola Support
Jun 29, 2014 | Motorola Cell Phones
Black screen
Master reset with hardware keys A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloaded content, ringtones, images, apps, and contacts. It does not delete data stored on the SIM card or SD card.
If the device menus are frozen or unresponsive, you can master reset using hardware keys. To perform a master reset, follow these steps:
  1. Back up all data on the internal memory. You won't be able to since there is no display.
  2. Turn off the phone.
  3. Press and hold the Power and Volume Up keys simultaneously.
  4. Continue to hold the keys past the T-Mobile splash screen.
  5. Release all keys when the Android system recovery screen appears.
  6. Press the Volume Down key to highlight 'wipe data/factory reset.'
  7. Press the Power key to select.
  8. Press the Volume Down key to highlight 'Yes -- delete all user data.'
  9. Press the Power key to select. The unpacking Android screen appears, and once complete with the reset, the Android system recovery screen reappears.
  10. Press the Volume Down key to highlight 'reboot system now.'
  11. Press the Power key to select. The phone will automatically restart.
Mar 13, 2014 | T-Mobile Prepaid Prism II
My garmin freezes on startup. Can't master reset
You could try pressing and holding the power button for 10 seconds. If that doesn't work, try a master reset by:
Start with the unit off and unplugged from power.
  1. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  2. Continue touching and holding the lower right hand corner of the screen then power the unit on.
  3. Release the power button when the device powers on.
    • You will see a new message: "Do you really want to erase all user data?"
  4. Remove your finger from the touchscreen when this message displays
  5. Touch "Yes"
  6. Restart the unit
Please let me know if it helps.
Thanks
May 03, 2010 | Garmin nuvi 1350 Car GPS Receiver
Wrong display on boot up.
Is the post/splash screen clear on initial boot up? Can you see the post information clearly?
Sep 29, 2009 | Intel D865GVHZ Motherboard
Start up screen
I had this same issue on my 930. You need to edit the bitmap with paint and make sure the dimensions are the exact same as the splash file. Rename the new splash screen with the same filename for the old startup screen and delete the old. That should fix it
Jan 04, 2009 | Tomtom One XL GPS Receiver
Display problems with nuvi 260
You may have to send in for service. A bad screen normally is not a good sign. Sorry.
If you are sure that the updates have been downloaded your only other option is:
Trying a full master reset:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 260 series device: Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Feb 19, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Motorola Mobility RAZR V3x Cellular Phone Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
