Question about Vizio VF550XVT 55 in. LCD TV
When watching tv the red color only has a jitter. What settings will fix this?
Colors are very off, epecially whites.
if contrast etc not set incorrectly it may be a issue on the main board which processes all signal inside the set===a 37 inch might cost you more to fix than to replace.
Mar 14, 2012 | Dynex DX-LCD37 TV
When tweaking the motion settings low makes everything jitter really bad and high is a bit better. Even at custom 10/10 it still jitters enough to annoy me. Is it a defective tv? The strange part is...
Try checking the Hz settings on each channel you use. It may be that what you happen to put a setting on is only effective on that channel. Which means if you had to originally set it for 60 or 120hz on the hdmi channel, then you may have to do the same for your tv/satellite channel.
Jan 13, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
MITSU VS 50705 SCREEN JITTERS WHEN COLD.STARTS AFTER A FEW MIN'S OF WATCHING,LASTS FOR 5 MIN'S,THEN GOES AWAY COMPLETELY ??
set tv on fire,then threw it down the stairs...
now,why would i tell you how i fixed it for 'free' ,when you
charge ''me'' for answers..hmm
Nov 02, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Hour glass cannot adjust red horizontal convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2009 | Mitsubishi VS-50605 50" Rear Projection...
I have a glow or a shadow around everything I watch...I tried the converse blue but i dont know if i did it right bc it didnt work...how can I fix that?
CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 17, 2009 | Philips 50P8341 50" Rear Projection...
My TV looks like if i was watghing a 3D Movie.
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Jan 26, 2009 | Philips 55PP9401 55" Rear Projection...
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Vizio VF550XVT 55 in. LCD TV Logo
752 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
