Question about Nokia N95 Cellular Phone
Phone turns off its own
How can i fix this my nokia n95 turns off on its own while i am using it then turns back on several seconds later
  • Anonymous Dec 23, 2007
    I have the same problem. Firmware update did not help.
  • 3 Answers
I have a N95-3 and have found that the problem seems to be a combination of Loose battery and faulty or flaky headphone jack. I have tried wedging the top right side of the battery with a few thicknesses of 1/4" wide paper between the battery and the battery slot. This seems to push the connectors on the left side a little tighter and reduces the shut down incidences. If the battery is loose just handling the phone and especially pushing the side buttons or squeezing the case will disconnect the battery and shut the phone off. Sometimes the shutdown is immediate and other times the display will slowly fade to black and the phone needs to be restarted. If the battery is really loose the restart button will not give the jolt start feel and you'll be forced to open up the battery case and fiddle to get the battery making better contact.Hope this helps.
Posted on Oct 11, 2009
    New Friend:
I wedged a cardboard square on the bottom left-hand corner just underneath the battery and it seems to work! (note: batt. connectors are at the top left of batt.)!
Posted on Jan 14, 2013
  • loftlivingde
    loftlivingde Jan 14, 2013
    President:
  • 1,944 Answers
Update your firmware to the latest one with Nokia Service Updater.
Posted on Dec 16, 2007
My nokia n95 8gb phone are hang problem and i am flash this mobile but no soul this problem my mobile are working 15 , 20 second and this hang please help me
I had this problem after i updated the firm wire. Later I changed it bake it to the recommended firm wire it is working properly.
Try hard format. If u r lucky that may solve ur issue
http://discussions.europe.nokia.com/t5/Nseries-and-S60-Smartphones/N95-8Gb-hard-reset/td-p/298911
Dec 21, 2010 | Nokia N95 Cellular Phone
How do you reset a nokia n95 8gb
For a decent reset that will reset most problems make sure the phone is turned on, then just take the battery out, wait at least 30 seconds so the phone can discharge. Then put the battery back in and turn on. Solves 99% of issues.
Nov 23, 2009 | Nokia N95 Cellular Phone
Hi sir hope u will be all right i gort a problem with my n95 its simple edition.the problem is with the camera when i opend the camera a second window come but only for 1 seconds can u tell me whts the...
i have a Nokia N95 and it seems it's trying to open both cam's front and back .. remember you have this option to select which one to use back or front. If you can't fix this problem then you will have to reset to factory settings by doing this go to
tools
settings
General
Reset to Factory
click yes
Sep 18, 2009 | Nokia N95 Cellular Phone
Bluetooth pairing Nokia N95 with Toshba Satellite
btooth has several stages
search
authentication
pairing
coneect etc..........
passcode is required in authentication
it is very simply
the passcode can any natural number
the same that u use in the first device should be use in the second devise when asked.
if you type 1 on first device .
the same 1 should typed on the second device
this is for your security. that u r connecting with the required device
Dec 14, 2008 | Nokia N95 Cellular Phone
Unlockig code
and follow the steps
Howto use:
You need two mobile phones.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
second mobile. Install FExplorer on the second mobile phone. Create
the directory E:SystemRecogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345
Aug 03, 2008 | Nokia N95 Cellular Phone
N95 copy
Try to restore it to factory default by typing 1122 then press send key
Jul 25, 2008 | Nokia N95 Cellular Phone
Nokia n95 screen problems
Try a hard reset on the device. Pull the battery out whle the device is on. Then put back in.
If that doesn;t work, try reloading the OS.
Jun 02, 2008 | Nokia N95 Cellular Phone
My screen is upside down N95
leave the phone switched on and remove the battery and sim card . leave for 10 seconds then insert the battery with no sim , turn the handset on , after a while when the phone has fully loaded leave it switched on and then remove the battery again , leave for a further 10 seconds and then insert the sim card and the battery when you now turn on the phone you should see the problem has been fixed , if however you are still experiencing the same problems then you will have to contact nokia and get a warranty repair .
May 07, 2008 | Nokia N95 Cellular Phone
Nokia N95 Wont start up properly
hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Jan 29, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
387 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
