Question about Maclaren Major Elite Umbrella Stroller
Just rec new stroller.Should there be 2 dents in the top cross bar located on the back and 2 dents in the bottom cross bar located underneath?
I bought one of these a couple of weeks ago and mine has the same dents, think its because they have to cross over each other so one of each bar isnt totally straight. seems as though its a standard thing.
Posted on Oct 06, 2009
How do u put the seat cover back on the quinny zap?
the seat slides back on threw the bars on the inside,the pram need be folded for you to do this,you start from the bottom? not very easy to do,very stiff,so really needs 2 people,sum 1 pulls the top and sum one dose the bottom at the same time,u thread the material threw the inside of the bars,then push the 2 little black clips in to place,caroline
Jul 07, 2011 | Quinny ZAPP Stroller
How do i fold my stroller?
The way to fold it is to push up the buttons on the handle bar (also used to adjust the bar) and then kick the kick plate on the bottom. If that's still not working. This video should help you. She folds the system and explains how to do it at 5:00. You can also see how everything else works as well with converting from the bassinet to the stroller for toddler. Hope that helps!
Nov 08, 2010 | Silver Cross 3D Jet Sport Standard...
How to install the peg perego car seat adapter on
You have to put the big bar through the wholes in the side attachments first before attaching the spring loaded bar. The big bar should be facing toward the front of the stroller.
Once the bars are all attached, the to clicky slots on the Peg should click into the small cross bar and the spring loaded bar. The big slot on near the back of the Peg should rest on the big bar.
Mar 05, 2010 | Baby Jogger City Series Single Stroller
How do you make this stroller sit up
Lift the flap on the back of the seat to reveal the cross bar. You will need to pull up on the cross bar to release the seat lock. Then you can raise or lower it and then release the bar to lock it back in. Hope this helps. Good luck.
Dec 03, 2009 | Cosco Juvenile 01867 Stroller
A screw is missing from my maclaren buggy
hi,
I had this problem and just went to my local diy shop and they sold me a nut, bolt and washer. You just need to make sure it'll fit in the hole. Cost me 15p!
May 22, 2009 | Maclaren Quest sport - Placid Blue...
I cannot close milano stroller
I read the answers written here and I can see why some people are still confused. So I will try to break it down into steps:
1. With your foot press down on the lever numbered 1 at the bottom of the stroller. This lever holds in place.
2. With your foot press down on the the lever numbered 2 at the bottom of the stroller. Hold this lever down with your foot because it does not lock in like lever numbered 1.
3. While your foot is still pressed on lever number 2, hold the handle bar with both hands and **** it forward. This step is rather tricky. So think of it as punching both hands forward horizontally while holding the handle bars.
At this point the stroller will come apart and fold. Now if you see that the stroller is stuck in position and does not fold or comes apart only with a lot of force then you have to oil the joints. Use WD-40 and spray it on the joints on the side of the stroller located right below where it say "PegPerego" on the body of stroller. That is where the joint where the stroller folds is located.
Hope this helps.
Feb 22, 2009 | Peg Perego Milano XL Stroller
Hi, I have a peg perego, single child stroller, standard, Not sure which model. It has just a bar not a tray. Anyway, I CANT figure out how to fold it. Theres a carrying handle on the side so I know it...
Hello, if this is an umbrella type stroller, you first release a catch on both handles to unlock the frame. These catches are located on the front and can be pulled up with your fingers. If you watch, they release the bottoms of each side from the front. You then pull the handle or lever located on the cross bar at the back up toward you. Thus collapses the frame as the wheels come together and the stroller then locks closed in the standing position and can be carried by the handle on the side. Greetings from Oz.
Dec 14, 2008 | Peg Perego Aria MT - Toffee Standard...
2007 Hyundai Santa Fe Limited
Hey all,
I was able to get installation instructions for the cross bars from http://www.capitolhyundai.com and from http://dealerfit.com.  Thanks much to these folks for providing a pdf of these instructions free of charge!
Below is the text from the instruction set that worked best for me.  The other instruction set was nearly identical but it had an alternate Step 2 which involved using a small plastic pry bar.  I added that alternate Step below in the instruction step.  Hopefully I'm able to insert the image of each instruction set so that the Figures are visible.  Its actually not that easy getting the rear rail covers off and its pretty easy to crack them.  I'd recommend gently rocking the covers for a couple minutes in order to loosen them up.  Once you get the covers off, the rest of the install is a breeze and can be done in 2 minutes.  If you have questions, go ahead and contact me.  I also took several photos of my install and that might be helpul.  Cheers!
-LePig
SANTA FE 2008 PIN U8210-28000 Cross Bar Assembly Installation Procedures
Kit Contents: • (2) Cross Bar Assemblies Required Tools: • Flat Head Screwdriver
INSTALLATION INSTRUCTIONS
1. Carefully unscrew and remove radio antenna. 2. Grasp the rear rail covers with both hands. Squeeze and pull up & inwards (toward the center of the vehicle) to remove covers. Take care not to break off the tabs by lifting the rear section of the cover first (Figure 1). Be careful not to scratch, damage or dent any painted surfaces. DO NOT PRY AGAINST THE VEHICLE BODY, THIS CAN CAUSE DAMAGE TO THE VEHICLE. 2. - Alternate Method - Locate notch in rear of each cover to insert plastic pry bar.  Remove cover by prying up (with tool) and lifting rear at 45 degree angle (Fig 1). Be careful not to scratch, damage or dent any painted surfaces. DO NOT PRY AGAINST THE VEHICLE BODY, THIS CAN CAUSE DAMAGE TO THE VEHICLE. 3. Check assembly clips for damage and dislocation. Replace if necessary. 4. Open the lever on one side of front/rear cross bar. Gently set the cross bar, with the arrows facing forward, into the channel of the side rails (Figure 2). Guide both sides into the track. 5. To adjust cross bars, open lever and place cross bars in desired location. Close lever (Figure 3). Try to move bars forward/back until they lock into place. 6. Reinstall rear covers by holding cover at a 45 degree angle and inserting the front tab into the rear of the roof rack. After aligning, snap cover in place (Figure 4). Be sure that the rubber lip does not interfere with the covers, and that the covers are fully seated. 7. Reinstall the radio antenna. Note: To remove the cross bars, remove the antenna, remove the covers, open lever of cross bar and slide to end of rail. Hold down locking fingers (on both RH/LH rear rail supports) with a flat head screwdriver (Figure 5). This will allow removal of cross bars from the rails.
Jul 02, 2008 | 2007 Hyundai Santa Fe Limited
Maclaren Major Elite Umbrella Stroller Logo
81 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
