Question about Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700
I had to reset the door lock to factory defaults. I have changed the master code back to what it should be. Now I need to program with the AL-DTM box. Lock doesn't recognize box. I think I need to add user 299, and I am entering the following once in programming mode. A2A299*A299* Please help if this is the correct code for adding user 299 for AL-DTM box, and what else I need to do. Thank you
  • 12 Answers
SOURCE: Alarm Lock Trillogy DL2800 and DL Windows Program.
If you can load DL windows onto a laptop instead of a PC, you can program directly to each lock using a AL-PC12 cable which connects from a 9-pin serial com port on your computer, to the 2-pin banana plug on the lock.(be sure to observe polarity). Cable is available from Alarm Lock. Some very useful downloads and information is available on their website - www.alarmlock.com
I hope this helps!
Posted on May 19, 2009
  • 3 Answers
SOURCE: Trilogy dl 2700 serries digital lock program managers code
First you need to know if you have a standard 2700 or the new enhanced version, it makes a big difference. Press any 2 buttons then star, if you get no response it is a standard version, if it beeps several times it is the new version. If it is the standard version, disconnect the battery and press any button. Now you are at factory default. Reprogram the master code, remember the master code and the operating code must b e the same length. 12345 A 1 A new master code A new master code. The master code is the only code that needs to be entered twice during it's programming. To set a manager code press; master code A2A new manager code, to set a new user code; enter master code or manager code A11A new user code. The programming must be done during the lock's unlock window so write down the procedure you intend to use to make things go quicker, if you need more time you can change the unlock window, it is probably set at the factoy 5 seconds. Press master code A45A4, this will give you a 20 second window to program the lock, when you are finished change the lock back to 5 seconds, press; master code A45A1, keep the open window short to conserve batteries.
Posted on Jun 24, 2009
jyackle5
  • 8197 Answers
SOURCE: I did change the master
ERASE ALL PROGRAMMING
(The "out of box" factory default will be loaded)
1. Remove the battery pack.
2. With battery power disconnected, press and hold
down ; for 10 seconds to ensure discharge of all capacitors.
3. Re-install the battery pack (lock will sound 3 short beeps).
If beeps are not heard, then restart at step 1.
4. Within 5 seconds after hearing the 3 short beeps, press
and hold ; until the lock begins to beep, then release.
5. A series of 5 RED LED and 5 beeps will be heard followed
by 10 seconds of silence, then 3 GREEN LEDs and 3 fast
beeps.
All settings and programming have been erased and the lock
is now ready for use. Note: All lock programming can also be
erased (without need to disconnect the batteries) by entering
Function 99.
Or you can get the info on the link below bottom of page 11.
http://www.abs-hardware.com/Programing%20Manuals/Alarm%20Lock/ETPDL_PDL3000%20Programming.pdf
Good Luck please accept the answer
Posted on Oct 31, 2010
  • 963 Answers
SOURCE: I am trying to restore
This is the website for Alarm Lock, the manufacturer:
http://www.alarmlock.com
For your problem you are best served by calling them at 1-800-252-5625. They are located in New York, so east coast business hours. I,m sure they can hook you up with a technician that can help you.
Good luck--and please provide feedback if this helps!
Posted on Aug 26, 2011
  • 963 Answers
SOURCE: We have a Alarm Lock
First find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version.
You will also find contact information on theirs site for further technical assistance.
Posted on Nov 08, 2011
Reprogram master code
on the keypad press the following...
(old master code) wait for green light
press and hold AL key until multiple beeps are heard. this puts you into program mode.
TO ENTER NEW MASTER CODE press the following keys:
  • AL 1 AL (new code) AL (confirm new code) then press the star key
  • to EXIT program mode hold down any key for 3 seconds
  • test new master code
Jun 23, 2014 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Securety code eror
check this one
Master Code Generator will Instantly generate your Nokia's Master security code.
This service can be used if you need to reset your Security Code.
Your IMEI: 356924034968264 --
Your Nokia Master Code: 2401254345
or this one
Nokia 5000 hard reset
You can format your Nokia 5000 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Some Nokia phone can be reset via this menu option
Press menu button or enter Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore > YESRestore factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only - to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
IMPORTANT!
Formatting the device will permanently erase all user data and settings as well as add-on applications and operator specific settings
goodluck
Apr 21, 2014 | Nokia 5000 Cellular Phone
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Security code unlock for nokia 5130 c-2
You can do a master reset code to your mobile. That would restore your device with default factory settings. Once when your device turns back to default settings your security code also changes to default code. Either 0000 or 12345 . You can get the free master reset code for your mobile from www.Unlocking4free.com just submit your IMEI number here and the free master reset code will be provided.
Apr 02, 2012 | Computers & Internet
Forgot lock code
What is your mobile model? If it is a basic model Nokia phone you can get the free master reset code from www.Unlock-free.com . Once you enter the master reset code. Your mobile will become fresh and restored to factory settings. Your phone lock code also will be changed to default code. Either 0000 or 12345
Mar 29, 2012 | Cell Phones
How do I get a manual for YL88 electronic lock
Okay Guyz n' Galz...Finally I solved this by lot of iterations. I have YL-88, YL-68 and D77 Digital locks. They are all made by Yili from China with buttons placed circularly. Warning, to reset it might not work on button placed in square pattern (YL-99).
Default master code is 0123# all the locks mentioned above.
Now to reset the master code, press and hold the reset button(red) for 2-5 secs on the battery pack, and remove one battery. Release reset button. Give 5 to 10 secs. Then press and hold reset button first, put back the battery into it.
Now the lock is reset to factory default. i.e., 0123#.
Warning: Make sure the default works before you close the door and lock.
Now to apply new master code: Enter default 0123# and wait till the sound is gone and the light is still lit. Start your new code starting with '0' and end with * key (not the # key). It will beep twice. Your new master code is ready to use. Now if it does not beep twice. Try from the begining with default code.
Enjoy
Your'
Problem solver!
Jan 04, 2012 | RTO Chrome YL88 Keyless Electronic Digital...
How to reset codes on a yl88 keyless electronic digital door lock lost the manual and cannot work it have no emergency module
Enjoy
Your'
Problem solver!
Oct 02, 2011 | RTO Chrome YL88 Keyless Electronic Digital...
My Adel Trinity 788 fails when read my (master) fingerprint (red light - two beeps). I already tryed to reset to factory defalts, pushing the 2 buttons (holding), removing a battery, then put the battery...
according to what he says:
if your lock does not recognize its master finger ud.hizo an attempt to reset and apparently not properly reset as initially ud. must press the two buttons at once not stop pushing, in followed remove a stack, reinstall again the battery immediately is oira one beep should expect from five to seven seconds is oira a different sound until that moment is reset your veneer and is at that very moment that are left of pressing the buttons.
then begins the process of adding tracks
http://www.segurilex.com
Feb 22, 2010 | Trinity Keyless Biometric Fingerprint Door...
How to reset codes in Kaba ilco Unican 4000 access control
I have a Unican 4000 series door lock and need to find code for it
Dec 20, 2009 | Locks & Locksmithing
Feb 18, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700 Logo
1,373 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
