Question about Cell Phones
I cannot turn off the Nokia E66 phone autolock period. When I try and turn it off, i can an error saying unable to unlock phone. I also cannot extend the autolock period beyond 20 minutes
Unlock
If you want to unlock it from network lock,you can get an unlock code for your Nokia E66 mobile phone from Simpleunlocking.com .Here you have to specify the country name,the current network provider and IMEI number of your mobile phone.Then you can get an unlock code from them at reasonable cost and unlock it.
Jun 21, 2013 | Nokia E66 Smartphone
Hi, i want to lock my c6 phone with a passcode or password!! becoz of my brothers provoking my privacy??
To activate lock code on Nokia C6:
  1. Select Menu
  2. Settings and Phone
  3. Phone mgmt.
  4. Security settings
  5. Phone and SIM card
  6. Select Lock code
You can also set the phone autolock period to avoid unauthorised use, set a time-out after which the device automatically locks. A locked device cannot be used until the correct lock code is entered. To deactivate this option, select None.
Jun 29, 2011 | Nokia C6 Smartphone
Hi iam having nokia e63 .. i forgot d password for phone autolock period..!! can any 1 help plss ...!! emei no: 354329041696001
The only way to unlock any seting on yuor phone is to go to a cellphone technician.They have the program how to unlock previous settings..
Jun 18, 2011 | Nokia Unlock N70 N71 N72 N90 6630 6680...
I have a Nokia E71x that I've been working on and all seems kosher except I am unable to unlock the unit. When I am instructed to hit the functions key after hitting the unlock button nothing happens. I...
It is not lightening fast. It should be done in two seconds after you press unlock.
To permanently unlock it you must go to Menu->Tools->Settings->General->Security->Phone and SIM Card->Keypad Autolock Period. Here you must disable it. Then your phones keyboard will not lock up automatically.
I hope it works. I have told you the sequence from my E71.
Nov 23, 2010 | Nokia Cell Phones
I'm using Nokia E71 & I want to change the autolock period which early on was put in USER DEFINE mode to "NONE" but when I click NONE I got message "unable to unlock phone" Wats the problem & how...
A strange thing indeed.
I assume you have tried switching phone off and on?
I would reset the phone to basic settings.
Settings > General > Factory settings. This might help you.
Jun 24, 2010 | Nokia E71 Smartphone
Nokia e66 bluetooth unable to perform bluetooth operation
It is a software problem. You have you try resetting the phone.
Thank you
Mar 30, 2010 | Nokia E66 Smartphone
I want to put password for my Nokia N73 mobile
  1. Press the Nokia Menu key to the left of the 1 and 2 keys then choose Tools.
  2. In the Tools screen click on Settings
  3. In the Settings screen click on Security
  4. In the Security screen click on Phone and SIM
  5. Scroll down and select Lock Code
  6. Now type ‘12345’ and then choose OK with the left Selection key. ‘12345’ is the default lock code for the Nokia N73
  7. Next type your new lock code then choose OK with the left Selection key. Your lock code can only include the numbers 0 to 9. You will be asked to enter it again. Do this then choose OK with the left Selection key again. You will see a message that says ‘Lock code changed’
  8. Next click on Autolock period. You can set your phone to lock itself automatically after a period of inactivity. To do this click on User defined with the scroll key. Now enter the number of minutes after which you want the phone to automatically lock itself and choose OK with the left Selection key
  9. You will have to enter the lock code you set up and then choose OK, and finally you get the message ‘Code accepted’. Now after the period of time you set the Nokia N73 will lock itself and a screensaver will appear to show that it is locked
Unlock the phone
To unlock the phone select Unlock with the left Selection key then type the lock code and choose OK with the left Selection key. The message ‘Code accepted’ will appear and you will be able to use the phone.
Disable autolock
If you decide you want to disable the autolock the go back to the Security Settings screen (see above), scroll to where it says Autolock period then click with the Scroll key and click. Choose None. You will need to enter the lock code and choose OK with the left Selection key. The message ‘Code accepted’ will appear and the Autolock period will be reset to ‘None’.
Oct 09, 2009 | Nokia Cell Phones
Hey i cant take videos on my nokia e66....each time i try..it says ``system error"????/ what's wrong?
save everthing you can from off the phone,if you have to many videos try removeing some befor try it agin. trun phone off then back on (soft reset) if no luck try master rester. good luck
Aug 27, 2009 | Nokia E66 Smartphone
Keypad lock
Setup the keypad lock by going into the settings
Settings
Phone
Security Settings
Phone and Sim
Autolock Period
Lock Code (11111 for new phones)
Set Autolock Period
Nov 07, 2007 | Nokia N73 Cellular Phone
Cell Phones Logo
101 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
