My laptop is a hand-me-down from about 2004. it has been slow for awhile, but worked fine. today i went to open it and it shut down. it then turned back on and shows a blue screen that says "Your computer has encountered a problem and shut off to prevent further damage". it only shows up for a second and then shuts off. after it shuts off, it turns back on and does it all over again. what do i do?
While the computer is booting up you should be able to hit F8 repeatedly and be offered the option to boot into safe mode. This will allow you to access your files.
Since the computer is already slow, I would back up these files to a thumb drive and just reformat using restore disks if you have any. If you don't let me know and we can explore further.
Posted on Sep 24, 2009
    President:
  • 1,187 Answers
Turn ON computer and press [F8] key.
On the menu, select "Start computer in last known good configuration" (or similar wording).
It should start normally.
I can't close my page with the red bottom on the top left hand side today to open another page. Would you please help me. Thank you.
Try a reboot, that should correct that problem.
If you are unable to shut it down from the menu bar, press and hold the power button until it turns off. When it reboots, it will ask if you want to open all the programs you were running when you shut it down. I usually do not open them, because never sure which one caused the problem.
Feb 25, 2015 | Apple Computers & Internet
I have a 1995 isuzu trooper awhile ago my car wouldnt start cause i hit the alarm switch i thought i left it alone for awhile and it started. so today i went out to a store and went to start my car back...
Have the starter solenoid checked. With a continuity tester check if the positive terminal on the solenoid receives a signal when the switch is turned. If it doesn't then the switch is at fault.
Aug 23, 2017 | 1995 Isuzu Trooper
Had a problem new yrs eve. Drove home fine got in the drive and turned the key off the lights went off in the dash but the truck didn't shut off. Pulled the ignition fuse to shut off. Today truck started...
Sounds as if dimmer slider/switch is going to ground on this model the headlight switch should have a dimmer thumbwheel, if it is all the way up and then you feel the indent and that should turn the inside domelamp on, if it does not the switch is bad. also check your vanity mirror covers, sometimes the little pins that shot off the light when you close the mirror covers stick open and run your battery down over night or in a few hours. Charge battery and then check these lights first, depress white pins to shut off.
Jan 04, 2010 | 2001 Chevrolet Blazer
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
92 sable shuts off when slowing down
its over heating, check water pump
Apr 30, 2009 | 1992 Mercury Sable
I HAVE AN ACER ASPIRE 4315-2004 WHICH I GOT IN DECEMBER 2007. I HAVE WINDOWS VISTA ON IT. THE OTHER DAY WHEN I WENT TO TURN IT ON IT WAS VERY SLOW AND WHEN IT FINALLY STARTED I COULD NOT CONNECT TO THE...
WELL FIRST YOU NEED TO CLICK ON THE START BUTTON ON THE BOTTOM LEFT HAND CONNER OF THE MONITOR. NEXT TYPE IN MSCONFIG THEN PRESS ENTER. IT IS GOING TO ASK YOU IF YOU GIVE IT PERMISSION TO OPEN THE FILE CLICK ON YES. THEN WHEN IT OPENS UP CLICK ON THE STARTUP TAB BE VERY CAREFUL TO NOT UN CHECK ANYTHING THAT THE COMPUTER REQUIRES TO START UP. UN CHECK ANYTHING THAT HAS TO DO WITH AOL, ANY INSTANT MESSANGER YOU MIGHT HAVE INSTALLED ON UR COMPUTER, AND ANY OTHER PROGRAM THAT YOU NOTICE THAT YOU MIGHT NOT NEED TO START UP WHEN UR COMPUTER STARTS UP. THE TENDS TO BE A MAJOR FACTOR WHEN COMPUTERS ARE RUNNING SLOW OR START UP SLOW.N IF ANY FURTHER QUESTIONS OR INSTRUCTIONS ARE NEEDED PLEASE FEEL FREE TO CONTACT ME AT JOSEHANDERSON@AOL.COM I GIVE YOU MY EMAIL BECAUSE I DONT KNOW HOW TO MAIL ANYONE ON THIS WEBSITE NOR HOW TO REPLY TO SOME UNLESS YOU CAN TELL ME. THANK YOU AND I HOPE I HAVE BEEN ABLE TO SOLVE YOUR PROBLEM
Apr 14, 2009 | Computers & Internet
2006 ultra radio has no sound
This is a very common problem with this radio there is a part in the radio that controles volume and it breaks down after a period of time due to vibration... If you need any repair help you can email me at HRmotors@aol.com I no these radios inside and out and would be happy to help you- thanks
Jan 13, 2009 | Harley Davidson 426290 AM/FM Radio
Stalling truck
Sounds like it could be a number of things Coil breaking down,ignition module breaking down or a failing relay.Could be ignition relay or fuel pump relay.The relay is the quickest,easiest and cheapest option to try first.
Oct 20, 2008 | 2002 Chevrolet Avalanche
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
