Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Yellow light on power button keeps blinking but doesn't boot.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Yellow light means that your pc is on hibernate mode. try resetting the CMOS batt. to clear out the setting
Posted on Sep 24, 2009
    President:
  • 632 Answers
No beeps are heard, no CPU fan is turning on, only blinking yellow light. This brand usually experiences this problem.
  1. First, check the power supply. Disconnect connectors from the board and make a jumper wire for the green wire to any black wire. If the PS fan does not spin then it's busted, else proceed below.
  2. Reconnect connectors except the one with 4 wires, 2 yellow and 2 black, then switch on. If CPU fan turns on then you have a bad processor.
  3. If the fan is still not turning on then check the USB port pins for short circuit.. disconnect it from the board and switch on.
  4. Do the same with other hardware connected to the board.
PS: The metallic casing of computers must be connected to the common ground of the power utility to protect it from stray currents that result to damage of sensitive components such as processors, memory and hard disks.
Blinking lights???
With the unit plugged in and on, push the reset button for 30 seconds, and while holding the reset button down, pull the power supply plug out of the unit and keep the reset button down another 30 seconds, and THEN (still holding the reset button down) plug the power supply plug back into it and keep the button down for another 30 seconds.
That's a "30/30/30 Reset", and it should boot up fully reset.
Jul 20, 2014 | Linksys E2000UK) Wireless Router
Fan noise and blinking blue power light
green=power in motherboard.
blue=stand by.
yellow=memory powerd
Jun 13, 2013 | Gateway GT5622 PC Desktop
Sometimes the power button on my Toshiba Regza flatscreen doesn't work
There is a dry solder and this might require attention by a qualified service technician.
Jul 13, 2012 | Televison & Video
My computer doesn't send signal
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
May 20, 2012 | Dell Dimension 9200 PC Desktop
Cant turn my computer on and there is a yellow blinking light
How many blinks? Count and notice the patterns of the blinks (3 long blinks or 1 long blink followed by two short blinks).
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If all the above fails, you problem could be your Video Card or a motherboard issue.
Apr 14, 2012 | Dell Dimension E510 PC Desktop
If the computers lights are just yellow what does that mean?
Just Yellow when? Tell us what happens time you put the power cord in and press the power button? Does it try to boot? Do the lights blink? Hear any beeps? Hear any fans? Does anything ever appear on the screen?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge. Remove the Power Cord, Remove the Battery, Remove the Memory Cover on the bottom of the laptop and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 07, 2012 | Acer Aspire 5500 5570-2609 Laptop
No power.....light on power button just keeps blinking off and on (yellow)
sounds like a ram problem, though you could try to reset bios, to do this unhook power and open case and remove cmos battery and short out the two battery conections for 6 seconds, then reboot, if still not good sounds like ram has blown, remove some of the ram and see if it boots first
Feb 14, 2011 | Dell Computers & Internet
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
Laptop won't turn on
not sure but have you checked the backup battery inside
Nov 26, 2007 | HP Compaq nc8230 Notebook
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
469 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
